Author Topic: [Just for fun] dynamic 3dmesh, most code come from others  (Read 5186 times)
qjchen
  • Best wishes to all
« on: June 15, 2010, 10:31:39 AM »
Thanks to David Bethel : http://www.cadtutor.biz/forum/showthread.php?t=5457
and
the author of http://autolisp.mapcar.net/lambda.html (sorry I dont know German, I cant get the author's name)
I just add some code to enjoy myself about the dynamic 3dmesh
;;;by David Bethel : http://www.cadtutor.biz/forum/showthread.php?t=5457
(defun draw_mesh (vlist mmesh nmesh mflg nflg / cflg)
(and (= (type vlist) 'LIST)
     (= (type nmesh) 'INT)
     (= (type mmesh) 'INT)
     (< nmesh 256)
     (< mmesh 256)
     (> nmesh 2)
     (> mmesh 2)
     (cond ((and nflg mflg) (setq cflg 49))
           (nflg            (setq cflg 48))
           (mflg            (setq cflg 17))
           (t               (setq cflg 16)))
     (entmake (list (cons 0 "POLYLINE")(cons 66 1)
                    (cons 6 "BYLAYER")
                    (cons 10 (list 0 0 0))
                    (cons 70 cflg)
                    (cons 71 mmesh)(cons 72 nmesh)
                    (cons 39 0)))
     (foreach v vlist
             (entmake (list (cons 0 "VERTEX")
                            (cons 6 "BYLAYER")
                            (cons 10 v)
                            (cons 70 64))))
     (entmake (list (cons 0 "SEQEND")))
;;;; from http://autolisp.mapcar.net/lambda.html
(defun genlist(expr steps xpi ypi scale / plist tlist xn yn zn)
  (setq plist nil)
  (setq xn 0.0 yn 0.0)
  (repeat(* xpi steps)
    (setq tlist nil)
    (setq yn 0.0)
    (repeat(* ypi steps)
      (setq zn(* scale ((eval expr) xn yn)))
      (setq tlist(append tlist(list (list xn yn zn))))
      (setq yn(+ yn(/ pi steps)))
    (setq plist(append plist tlist))
    (setq xn(+ xn(/ pi steps)))
  plist
;;;the following is by qjchen@gmail.com
(defun c:test ( / ent1 gr height scale temp)
  (setq temp (getvar "cmdecho"))
  (setvar "cmdecho" 0)
  (command "._-view" "_top")
  (command "._-view" "_swiso")
  (command "zoom" "w" "-10,-10" "15,15")
  (setq height (getvar "viewsize"))
  (while (= (car (setq gr (grread nil 5 0))) 5)
    (if (setq ent1 (entlast))(entdel ent1))
    (setq scale (* (/ (- (cadr (cadr gr)) 10) height) 5))
    (draw_mesh (genlist '(lambda (x y /) (* (cos x) (cos y))) 10 3 3 scale) 30 30 nil nil )
  (setvar "cmdecho" temp)
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
Re: [Just for fun] dynamic 3dmesh, most code come from others
« Reply #1 on: June 15, 2010, 08:03:51 PM »
Interesting!  :-)
Perhaps another way to code it:
(defun c:test ( / foo spc mesh gr )
  ;; © Lee Mac  ~  16.06.10
  (setq foo (lambda (x y) (* (cos x) (cos y))))
  (setq spc
      (or
        (eq AcModelSpace
          (vla-get-ActiveSpace
            (setq doc
              (vla-get-ActiveDocument
                (vlax-get-acad-object)
        (eq :vlax-true (vla-get-MSpace doc))
      (vla-get-ModelSpace doc)
      (vla-get-PaperSpace doc)
  (setq mesh (LM:AddMesh spc 41 41 (LM:GetPointList foo -10 -10 10 10 0.5 1)))
  (while (= 5 (car (setq gr (grread 't 13 0))))
    (vla-put-Coordinates Mesh
      (LM:3DPointVariant
        (LM:GetPointList foo -10 -10 10 10 0.5 (/ (cadadr gr) 2.))
(defun LM:AddMesh ( space m n lst )
  (if (and (< 2 m 256) (< 2 n 256))
    (vla-Add3DMesh space m n (LM:3DPointVariant lst))
(defun LM:3DPointVariant ( ptLst )
  (vlax-make-variant
    (vlax-safearray-fill
      (vlax-make-safearray vlax-VBDouble
        (cons 0 (1- (* 3 (length ptLst))))
      (apply 'append ptLst)
(defun LM:GetPointList ( foo xmin ymin xmax ymax inc scale / result )
    (lambda ( x )
      (while (<= (setq x (+ x inc)) xmax)
          (lambda ( y )
            (while (<= (setq y (+ y inc)) ymax)
              (setq result (cons (list x y (* scale (foo x y))) result))
          (- ymin inc)
      result
    (- xmin inc)
qjchen
« Reply #2 on: June 15, 2010, 11:49:00 PM »
Thank you, Lee mac
I find that the speed of your code is much quick.
and, vla-Add3DMesh is better, because sometimes the entmake of 3dmesh need more code and hard to understand.
Thanks again.
« Reply #3 on: June 16, 2010, 05:26:08 AM »
You're welcome  :-)
« Reply #4 on: June 16, 2010, 05:31:24 AM »
Another one of my favourites - a hyperbolic paraboloid  :lol:
  (setq foo (lambda (x y) (- (* x x ) (* y y))))
  (setq spc
      (or
        (eq AcModelSpace
            (setq doc
      (LM:3DPointVariant
        (LM:GetPointList foo -10 -10 10 10 0.5 (/ (cadadr gr) 100.))
  (vlax-make-variant
    (lambda ( x )
          (lambda ( y )
          (- ymin inc)
      result
    (- xmin inc)
qjchen
« Reply #5 on: June 16, 2010, 07:46:22 AM »
:) beautiful  dynamic hyperbolic paraboloid figure~
« Reply #6 on: June 16, 2010, 07:55:28 AM »
A Pringle  8-)
qjchen
« Reply #7 on: June 17, 2010, 10:40:26 AM »
:) , I also like the following spiraling wave function, so I modify the up two code as following, they almost do the same
     (< nmesh 256)
     (< mmesh 256)
     (> nmesh 2)
     (> mmesh 2)
           (t               (setq cflg 16)))
                    (cons 6 "BYLAYER")
                    (cons 70 cflg)
                    (cons 39 0)))
     (foreach v vlist
                            (cons 6 "BYLAYER")
                            (cons 10 v)
                            (cons 70 64))))
  (setq plist nil)
  (setq xn (- (* pi xpi 0.5)) yn (- (* pi ypi 0.5)))
    (setq tlist nil)
    (setq yn (- (* pi ypi 0.5)))
      (setq yn(+ yn (/ pi steps)))
  plist
    ;(draw_mesh (genlist '(lambda (x y /) (* (cos x) (cos y))) 10 3 3 scale) 30 30 nil nil )
    (draw_mesh (genlist '(lambda (x y)
               (setq a (sqrt (+ (* x x) (* y y))))
               (+ (* x (sin (* 4 a))) (* y (cos (* 4 a))))
               (1+ a)
            ) 20 3 3 scale) 60 60 nil nil )
or
  ;; ? Lee Mac  ~  16.06.10
  (setq spc
      (or
        (eq AcModelSpace
            (setq doc
      (LM:3DPointVariant
  (vlax-make-variant
    (lambda ( x )
          (lambda ( y )
          (- ymin inc)
      result
    (- xmin inc)
3dmesh.png from my AUTOCAD 2004 render, not only from the code.
« Reply #8 on: June 17, 2010, 12:27:27 PM »
That render looks great  :-)
