Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
getfiled with two file types?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: getfiled with two file types? (Read 2705 times)
Global Moderator
Seagull
on:
December 08, 2004, 03:47:03 PM »
Does anyone know how to get getfiled to display two file types at once?
I am using
(setq path (getfiled "Select a File in the Folder you want to use" path "sld" 0))
But would like to display both SLD and SLB files.
Logged
King Gator
C3D user & customizer
Reply #1 on:
December 08, 2004, 03:58:51 PM »
Not exactly what you want, but seperate the sld & slb with a semi-colon and you will be allowed to select either one:
(setq path (getfiled "Select a File in the Folder you want to use" path "sld;slb" 0))
Logged
Global Moderator
Seagull
Reply #2 on:
December 08, 2004, 04:04:00 PM »
Jeff
Only the sld files show up!
Thanks anyway...
Logged
Needs a day job
Reply #3 on:
December 08, 2004, 04:10:04 PM »
CAB,
If you use the pulldown on file types you can choose what type to get. (with Jeff's code)
Ron
Logged
Global Moderator
Seagull
Reply #4 on:
December 08, 2004, 04:21:01 PM »
Well this works ok....
"sl*" and picks up both file types.
Logged
Villiage Idiot
Seagull
Superior Stupidity at its best
WWW
Reply #5 on:
December 08, 2004, 07:36:58 PM »
Code:
[Select]
(getfiled "" "" "sl*;sld;slb" 8)
Best of all worlds ...
Logged
Find me on
https://parler.com
@kblackie
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
