Author Topic: Changing XLINE appearance  (Read 3367 times)
gmyroup
« on: June 10, 2010, 01:28:22 PM »
Is there any way to change the appearance of an XLINE (contruction Line)?  I'd like to change the color and linetype to make construction lines more obvious.
Re: Changing XLINE appearance
« Reply #1 on: June 10, 2010, 02:00:55 PM »
different layer?
a reactor to change them?
what are your constraints?
TimSpangler
  • CAD Naked!!
« Reply #2 on: June 10, 2010, 03:18:22 PM »
I have mine come in on a non-plotting layer that is Magenta.
ACA 2015 - Windows 7 Pro
JCTER
« Reply #3 on: June 10, 2010, 03:31:31 PM »
You change 'em like you do any other object.
You can select all the xlines in the drawing using QSELECT, if they need put on a different layer after the fact.
Krushert
  • FREE BEER Tomorrow!!
« Reply #4 on: June 11, 2010, 09:34:35 AM »
Are you talking construction lines for a vertical?   :|
Andrea
« Reply #5 on: June 11, 2010, 11:01:05 AM »
there's mine...
maybe it could help..
;; XLINES and RAY on DEFPOINTS LAYER
;; By: Andrea Andreetti 2008-08-20
; (getLayers t)  = All Layers included XREF Layers
; (getLayers nil)  = All Layers EXCLUDED XREF Layers
(defun getlayers (xref / bav doc blk)
  (setq bav nil)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for blk (vla-get-layers doc)
    (if xref
      (setq bav (append bav (list (strcase (vla-get-name blk)))))
      (if (not (vl-string-search "|" (vla-get-name blk)))
  bav
(defun *XlineReactor_S* (call-reactor sci / layers Lname adoc Layers Nlayer xline)
(setq curLayer (getvar "CLAYER"))
(setq Lname "DEFPOINTS")
(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (if (member (strcase (car sci)) '("XLINE" "RAY"))
(if (not (member Lname (getlayers nil)))
    (setq Layers (vla-get-layers adoc))
    (setq Nlayer (vla-add Layers Lname))
    ;(vla-put-color Nlayer 5)
    ;(vla-put-linetype Nlayer "Dashed2")
    ;.....etc..
(setq xline (vla-item (vla-get-layers adoc) Lname))
(vla-put-activelayer adoc xline)
(defun *XlineReactor_E* (call-reactor sci / adoc clayer vlclayer)
      (setq vlclayer (vla-item (vla-get-layers adoc) curLayer))
      (vla-put-activelayer adoc vlclayer)
;;REACTOR SECTION
(if XlineReactor_S
    (progn (vlr-remove XlineReactor_S)
           (setq XlineReacto_S nil)
  (setq XlineReactor_S
         (vlr-command-reactor nil
                              '((:vlr-commandWillStart . *XlineReactor_S*))
(if XlineReactor_E
    (progn (vlr-remove XlineReactor_E)
           (setq XlineReacto_E nil)
  (setq XlineReactor_E
                              '((:vlr-commandEnded . *XlineReactor_E*))
(if XlineReactor_C
    (progn (vlr-remove XlineReactor_C)
           (setq XlineReacto_C nil)
  (setq XlineReactor_C
                              '((:vlr-commandCancelled . *XlineReactor_E*))
Keep smile...
« Reply #6 on: June 11, 2010, 01:41:03 PM »
Another (a reactor toggle  :-) )
(defun c:XLR nil
  ;; © Lee Mac  ~  11.06.10
  (  (lambda ( data foo1 foo2 / react )
       (if (setq react
             (vl-some
               (function
                 (lambda ( reactor )
                   (if (eq data (vlr-data reactor)) reactor)
               (cdar
                 (vlr-reactors :vlr-command-reactor)
         (if (vlr-added-p react)
           (vlr-remove react)
           (vlr-add react)
         (setq react
           (vlr-command-reactor data
             (list
               (cons :vlr-CommandWillStart foo1)
               (cons :vlr-CommandEnded     foo2)
               (cons :vlr-CommandCancelled foo2)
       (princ
           "\n** Reactor Activated **"
           "\n** Reactor Deactivated **"
       react
    "XLine-Reactor"
    'XLR:WillStart
    'XLR:Cancelled
(defun XLR:WillStart ( reactor args )
  (setq XLineLayer "XLineLayer") ;; <--<< Change this if necessary
  (if (wcmatch (strcase (car args)) "XLINE,RAY")
      (setq *clayer* (getvar 'CLAYER))
      (or (tblsearch "LAYER" XLineLayer)
          (entmake (list (cons 0 "LAYER")
                         (cons 100 "AcDbSymbolTableRecord")
                         (cons 100 "AcDbLayerTableRecord")
                         (cons 2 XLineLayer)
                         (cons 70 0))))
      (setvar 'CLAYER XLineLayer)
(defun XLR:Cancelled ( reactor args )
  (if (and *clayer* (wcmatch (strcase (car args)) "XLINE,RAY"))
      (setvar 'CLAYER *clayer*)
      (setq *clayer* nil)
Type 'XLR' to activate the reactor (only once), then 'XLR' again to deactivate  :wink:
