Author Topic: Activate new window  (Read 18435 times)
Activate new window
« Reply #15 on: November 27, 2003, 09:38:11 AM »
AddressOf is not valid in VBA, there is a workaround on the vbdesign.net website
SMadsen
Activate new window
« Reply #16 on: November 27, 2003, 09:46:16 AM »
Thought as much. It seemed a bit indigestible in VBA.
Oh, I better quit this thread now before I actually manage to learn VBA  :shock:
Activate new window
« Reply #17 on: November 27, 2003, 10:29:30 AM »
Try this in VBA to return the AddressOf ...
Public Function MyAddressOf(sFuncName As String) As Long
' This function Returns a function pointer of a VBA public function.
' Since the VB AddressOf operator which is not supported in VBA, call this
' function passing in the name of the function you want the pointer to.
' Generic return result so we can test our function calls for errors
 Dim lResult As Long
' To hold the handle to the current project
 Dim lHproject As Long
' To hold the ID of our function name as it is known by the system
Dim sFuncID As String
' To hold the final result (the return value of MyAddressOf)
' It is the same as if we had used the standard VB AddressOf function
' but remember, that is not supported in VBA
Dim lFuncPtr As Long
' The function name you passed in when you called MyAddressOf needs
' to be converted to Unicode in order for it to be found by GetFuncID
' This will hold that conversion
Dim sFuncNameUnicode As String
' Convert the passed in function name (the one we want the address of) to Unicode
sFuncNameUnicode = StrConv(sFuncName, vbUnicode)
' Get the current VBA project handle
Call GetCurrentVbaProject(lHproject)
' Make sure we got a project handle
If lHproject <> 0 Then
' Get the VBA function ID (this is the ID of the function we passed in to MyAddressOf)
lResult = GetFuncID(lHproject, sFuncNameUnicode, sFuncID)
' Again, check for an error so we don't try to get a pointer to
' a non-existent function.
If lResult = NO_ERROR Then
' Get the function pointer.
lResult = GetAddr (lHproject, sFuncID, lFuncPtr)
' Return the pointer to the function we passed in
MyAddressOf = lFuncPtr
End If
End If
End If
End Function
You will need to replace the AddressOf call in the code with MyAddressOf to make it work....
SMadsen
Activate new window
« Reply #18 on: November 27, 2003, 10:49:02 AM »
Cool. That's a keeper for future reference. Thanks.
Off to Vegas for now. See you guys in week or so!
Activate new window
« Reply #19 on: November 27, 2003, 12:38:36 PM »
Enjoy, I know I would. :D
SMadsen
Activate new window
« Reply #20 on: November 27, 2003, 12:45:03 PM »
Thanks Mark.
15 hours till the flight, though, so just got time to browse a bit
Activate new window
« Reply #21 on: November 27, 2003, 12:55:03 PM »
Bring back lots of info for us to read. <g>
Activate new window
« Reply #22 on: November 27, 2003, 12:56:20 PM »
Vegas!!! Welcome to the USA!!!!
(leave your cash at the craps table)
SMadsen
Activate new window
« Reply #23 on: November 27, 2003, 12:59:15 PM »
Quote from: Mark Thomas
Huh? Is it the purpose of AU to study something? C'mon, it's Las Vegas .. I expect to return with a trunk full of cash!
SMadsen
Activate new window
« Reply #24 on: November 27, 2003, 01:02:06 PM »
Or is it just to return in a trunk? :?
Activate new window
« Reply #25 on: November 27, 2003, 01:04:45 PM »
good luck them. :D
daron
Activate new window
« Reply #26 on: November 29, 2003, 01:13:31 AM »
Hah! I'll see you there. I'll probably be the only one trying to apply what I learn. I don't really care much for Vegas. Been there twice and was less impressed the second time than I was the first time.
