Author Topic: AutoCAD window hDC  (Read 6327 times)
dann.boy.001
AutoCAD window hDC
« on: June 09, 2010, 10:22:09 AM »
Hello!
Is posible to get hDC window of AutoCAD?
I want to use it to draw on autocad window with
windows api (in net system.drawing.graphics).
Maybe somebody know is posible it  :?
Best regards,
Danijel
Re: AutoCAD window hDC
« Reply #1 on: June 09, 2010, 11:40:44 AM »
It's possible ... I'll have to look up the reference though
« Reply #2 on: June 09, 2010, 12:12:12 PM »
To get the device context, you use the GetDC API call
Public Declare Function GetDC Lib "user32" (ByVal hwnd As Long) As Long
Dim hDC As Long = GetDC(hWndToAutoCAPApplication)
You may have to use IntPtr as the type though ... I have not tried it
dann.boy.001
« Reply #3 on: June 10, 2010, 05:25:26 AM »
Thank you Keith!
I will try this code, but I am not sure how to get hWndToAutoCAPApplication!
Best regards,
Danijel
« Reply #4 on: June 10, 2010, 08:54:55 AM »
Thank you Keith!
Best regards,
Danijel
:lmao: ok, sorry, that is the hWnd of the application window you want to modify ... presumably you have a reference to the application window, just not the hDC ... so you should have a hWnd property ... just pass that value to the function.
jgr
« Reply #5 on: June 12, 2010, 04:31:00 PM »
