Author Topic: Is it acceptable in your place....  (Read 4167 times)
craigr
« on: June 09, 2010, 07:52:37 am »
When drawing a line, say horizontal, 100' - Is it acceptable to drawi it in segments rather than ONE line?
We do mostly electrical dwgs. I have been trying to get our guys to stop drawing single lines in segments. When moving the lines, it is very annoying to only grab part of the line.
Sometimes there are even lines that have another one beneath it.
To me, this is just sloopy CAD work.
Is it tolerated in your place?
Self Taught and Still Learning!
Win7 Pro, AutCad LT  2013. Intel Xeon 8 Core 3.40GHz Processor, 8 Gig Ram, 3 LCD Monitors
Willie
  • Going nowhere slowly
Re: Is it acceptable in your place....
« Reply #1 on: June 09, 2010, 07:55:05 am »
Only one line is acceptable.
Soli Deo Gloria | Qui Audet Adipiscitur
Windows 7 Pro 64bit | Civil 3D 2011 and 2013| ArcGIS 10.1
Yogi Berra : "I'd give my right arm to be ambidextrous."
M-dub
  • SuperMod
  • I'm never sarcastic...
« Reply #2 on: June 09, 2010, 07:58:16 am »
No.  That is one of my pet peeves.  Someone needs to learn the Extend or Stretch commands... and have their knuckles rapped so they don't forget it.
Mike Williams | AutoCAD and Raster Design 2012 | Synergis Adept | Windows 7
jonesy
« Reply #3 on: June 09, 2010, 08:05:21 am »
Not acceptable here either. Its on my pet-peeves list. It is shoddy drafting and should be stopped, the sooner the better. Somebody here does it, but alas, it seems to be "Mr/Mrs Nobody" so we cant track it down.
It was one of the first things my trainer taught us years ago (in the days of the pen plotter) as the pen would keep drawing in the same place for as many lines as were there.
There are so many people out there who will tell you "You Can't".... what you have to do is turn it around and say"Watch Me!"
www.travelthrutime.com
JCTER
« Reply #4 on: June 09, 2010, 08:09:42 am »
overkill
« Reply #5 on: June 09, 2010, 08:11:25 am »
why not STOP using lines altogether, and ONLY draw polylines instead; in this manner the whole line would get moved, and not one segment at a time...
In the Civil world, polylines are also preferred as C3D has many tools designed to convert them into things like Alignments, and or Pipe Networks.
In my world polylines are preferred for better than 95% of everything I ever draw.
M-dub
  • SuperMod
« Reply #6 on: June 09, 2010, 08:34:47 am »
In I&E, polylines are overkill most of the time.  They have their uses, I suppose.
« Reply #7 on: June 09, 2010, 08:35:42 am »
yeah, plines work for us here but not in all situations and those drawings where folks draw multiple lines to represent a single line .. makes me want to choke someome
craigr
« Reply #8 on: June 09, 2010, 08:36:34 am »
What is 'I&E' ?
M-dub
  • SuperMod
« Reply #9 on: June 09, 2010, 08:37:18 am »
Instrumentation & Electrical
« Reply #10 on: June 09, 2010, 08:42:21 am »
funny .. I never did any instrumentation, but with every electrical schematic I have ever had the pleasure of working on, it was mandatory to use plines .. but then maybe your electrical is different from schematics and wiring plans
uncoolperson
  • Doing everything in metric inches!
« Reply #11 on: June 09, 2010, 08:44:27 am »
one line
when all else fails On Error Resume Next
Livin like I'm on borrowed time
Searching for the Ballmer Peak
« Reply #12 on: June 09, 2010, 08:44:46 am »
curious..how is a polyline overkill for this use...a (poly)line on a layer connecting to connection points on a diagram?
Se7en
« Reply #13 on: June 09, 2010, 08:45:05 am »
yes, that is acceptable; in fact i recommend putting several lines on top of each other all on different layers. I also like to have items with different start and end z values.
“Common sense is not so common.” ~Voltaire
--> Donate to TheSwamp.org <--
craigr
« Reply #14 on: June 09, 2010, 08:45:40 am »
I don't see what PLines are soooo much better than regular lines.
