Author Topic: Command for cannoscale  (Read 6621 times)
lamarn
« on: June 04, 2010, 03:09:10 PM »
Is there no normal command to change cannoscale??  :|
I don't like the flyout bar so much, the -cannoscale style is ...
Why isn't there not a normal dialog box..(!?)
kpblc
Re: Command for cannoscale
« Reply #1 on: June 04, 2010, 03:22:34 PM »
Sorry for my English.
Crank
lamarn
« Reply #3 on: July 14, 2010, 03:25:37 AM »
Not what i mean, i just want to SET the current in an old-fashioned menu.
Don't like the default, i hate fly-out toolbars..
It would be nice to have something like a set button in de scalelistedit function.
Tharwat
  • Hypersensitive
« Reply #4 on: July 14, 2010, 06:01:40 AM »
You can create a toolbar and include all the flyout tools inside it.  :police:
Regards
Tharwat
mkweaver
« Reply #5 on: July 14, 2010, 07:52:28 AM »
Does this do what you want?
cannoscale 1-1/2" = 1'-0";
Note that you cannot set a scale that doesn't exist in the scale list.
lamarn
« Reply #6 on: July 14, 2010, 09:59:37 AM »
Why is there no COMMAND to SET the scale??!!
« Reply #7 on: July 14, 2010, 10:10:33 AM »
What's wrong with a system variable?
lamarn
« Reply #8 on: July 14, 2010, 04:04:56 PM »
 Seems i have can not make my self more clear.
I am not looking for system vars. or code to program scale.
I just want an ordanairy AUTOCAD COMMAND to set my scale...   :?
« Reply #9 on: July 14, 2010, 05:47:58 PM »
Then why did you post this in the Auto Lisp forum?
http://catb.org/esr/faqs/smart-questions.html
« Reply #10 on: July 14, 2010, 06:41:59 PM »
mkweaver has already given you an "ordanairy[sic] AUTOCAD COMMAND"  :  CANNOSCALE
mkweaver
« Reply #11 on: July 14, 2010, 10:13:03 PM »
Let's see if I understand.
  1.  You want a way to set your annotation scale factor with simple menu call.
  2.  In addition, you would like that menu call to let you select the scale factor from a simple list.
Item one, can be performed with the snippet I posted using the cannoscale system variable as if it were an autocad command.
Item two, is a bit tougher.  There is no native autocad command that will do this, however, it can be done without too much work, if you have, or are willing to use doslib. http://www.en.na.mcneel.com/doslib.htm  We would be glad to help you learn how to do this.
If I've missed what you are wanting entirely, then I'm sorry for being dense - help me understand what you want.
lamarn
« Reply #12 on: July 15, 2010, 01:56:53 AM »
I do not see cannoscale as a command, its system var for manual input.
A simple set button in the scalelistedit will do..
