Hi Guys,
I am trying this and not having any real luck.
What I am trying to do is start a batch routine (*.bat) via lisp.
So far I have come up with:
(defun c:tr()
(command "start" "i:\\standards\\retail\\lowes\\lowes.bat" ))
This opens a command window and runs the batch but leaves the window open. I would like to have the window close.
In reading the help it says I can use the run command but this creates a line in your acad.pgp file. I would like it to be via lisp. The example of this in the help is:
Run, cmd /c,0,*Batch file to run: ,
The /c closes the window
Would I use startapp?
Any help or tidbits would be appreciated.
Thanks,
Pieter
