Author Topic: Matrix math problem - Align coordinate system  (Read 7833 times)
pkohut
« on: June 03, 2010, 10:44:11 AM »
I'm trying to figure out how the arx api for AcGeMatrix2d::alignCoordSystem works and just can't figure it out. Can someone help me out or provide a website with instructions to do this calculation? TIA.
The docs say:
Returns matrix that maps the coordinate system with the origin fromOrigin and the axes fromE0 and fromE1 to the coordinate system with the origin toOrigin and axes toE0 and toE1.
     (2d input vectors)                                  (matrix produced from origin e0 e1, row major)
fromOrigin = 10.0, 10.0   --->   mat1 (from coorinate system) = 1, 5, 10
    fromE0 = 1.0, 3.0                                           3, 7, 10
    fromE1 = 5.0, 7.0                                           0, 0,  1
  toOrigin = 20.0,  5.0   --->  mat2 (to coorinate system)   = 11, 17, 20
      toE0 = 11.0, 13.0                                        13, 19,  5
      toE1 = 17.0, 19.0                                     0,  0,  1
Matrix2d result = SetToAlignCoordSys(fromOrigin, fromE0, fromE1, toOrigin, toE0, toE1)
result = -3.25, 4.75,   5.0
         -4.25, 5.75, -10.0
          0.0 , 0.0 ,   1.0
What are the steps required to get the result?
Re: Matrix math problem - Align coordinate system
« Reply #1 on: June 03, 2010, 11:25:53 AM »
Linear Algebra isn't my strong point, so I welcome others to chime in, but this is how I see it:
You need to find a change of basis matrix, say P, from Coordinate system E0 to E1, given the basis vectors that span E0 and E1 (the coordinate axes), lets call them e01, e02, e03 (similarly for E1)
The basis vectors are linearly independent, so each of the basis vectors of E0 can be written as a linear combination of the basis vectors of E1, hence:
e01 = a11 e11 + a12 e12 + a13 e13
e02 = a21 e12 + a22 e12 + a23 e13
Where the a11, a12, etc are unique constants. So here we are saying, what do the basis vectors of E0 look like in terms of the new basis of E1?
Solving the above equations, we reach a change of basis matrix P, with columns:
( a11 a21 a31 )
( a12 a22 a13 )
( a13 a23 a33 )
Now:  E1 = P E0
pkohut
« Reply #2 on: June 03, 2010, 12:04:41 PM »
Thanks Lee. Well be diving in further when I get back in a few hours.
gile
  • Marseille, France
« Reply #3 on: June 03, 2010, 05:22:05 PM »
I'm not sure to undersand the task and certainly not able to explain the method due to my English more poor than may math and coding knowlege.
But it looks like you can use the Gauss Jordan method (search in an English Wiki)
Here's a LISP implementation of the method I used to Inverse a matrix
(GaussJordan '((1.0 3.0 0.0) (5.0 7.0 0.0) (10.0 10.0 1.0)) '((11.0 13.0 0.0) (17.0 19.0 0.0) (20.0 5.0 1.0)))
returns
((-3.25 -4.25 0.0) (4.75 5.75 0.0) (5.0 -10.0 1.0))
;; GaussJordan (gile)
;; Apply the Gauss-Jordan method to two matrices
;; Arguments : 2 matrices
(defun GaussJordan (m1 m2 / len mat todo cnt row col piv new)
  (setq len (length m1))
  (if (= len (length m2))
      (setq mat (mapcar '(lambda (x1 x2) (append x1 x2)) m1 m2)
    todo mat
    cnt 0
      (while todo
(setq row (nth cnt mat)
      col (mapcar '(lambda (x) (abs (car x))) todo)
(repeat (vl-position 0 (vl-sort-i col '>))
  (setq mat (append (vl-remove row mat) (list row))
row (nth cnt mat)
(if (equal (setq piv (car row)) 0.0 1e-14)
  (setq mat  nil
todo nil
  (setq piv  (/ 1.0 piv)
new  (mapcar '(lambda (x) (* x piv)) row)
mat  (mapcar
       '(lambda (r / e)
  (setq e (car r))
  (if (equal r row)
    (cdr new)
    (cdr (mapcar '(lambda (x n) (- x (* n e))) r new)
       mat
todo mat
cnt  (1+ cnt)
(and todo (repeat cnt (setq todo (cdr todo))))
      mat
LE3
« Reply #4 on: June 03, 2010, 05:42:31 PM »
hi Paul,
don't think i have used AcGeMatrix2d::alignCoordSystem, but AcGeMatrix3d::setToAlignCoordSys a lot... maybe by looking on the implementation or usage, you could figure out if could works for you, i can post some partial code, if you want...
MickD
« Reply #5 on: June 03, 2010, 08:13:00 PM »
here's some helper methods in C# that may give some clues
basically the class does the grunt work, you feed it a point for the origin and ortho vectors for the x,y vectors for the coordinate system you want to xform from and feed the new origin and vectors for the coordinate system you want to set, basically it's the same as setting a ucs if you like.
Don't get hung up on how they work internally as there's a lot to soak up, experiment with the out put to see how you need to use them.
Just remember that your vectors need to be orthographic (ie, at perp to each other) or it will fail.
hth
namespace DCSGeo
/// <summary>
/// Xform - transformation/translation and geometry helper classes
/// </summary>
public class Xform
public static Point3d UcsToWcs(Point3d point, Database db)
Matrix3d mat = new Matrix3d();
mat = Matrix3d.AlignCoordinateSystem(db.Ucsorg,db.Ucsxdir,db.Ucsydir,db.Ucsxdir.CrossProduct(db.Ucsydir),
new Point3d(),Vector3d.XAxis,Vector3d.YAxis,Vector3d.ZAxis);
Point3d retPoint = point.TransformBy(mat.Inverse());
return retPoint;
public static Vector3d UcsToWcs(Vector3d vec, Database db)
Vector3d retVec = vec.TransformBy(mat.Inverse());
return retVec;
public static Point3d WcsToUcs(Point3d point, Database db)
Point3d retPoint = point.TransformBy(mat);
return retPoint;
public static void WcsToUcs(Entity ent, Database db)
ent.TransformBy(mat);
- John Carmack
- J.R.R. Tolkien
pkohut
« Reply #6 on: June 04, 2010, 05:12:43 AM »
Thanks everyone. Definitely should be able to figure this out now.  I'm using Eigen as a matrix and vector library for a stand alone application (was looking at Blitz++ and TvMet), and have wrapped most of the AcGeVector2d and AcGeMatrix2d functionality using it.  Initially I was doing this because the Blitz++ and TvMet libaries are so cryptic to use, and I wanted to wrap them into something familiar. Anyways, found Eigen on Wednesday, and have re-wrapped most everything.  So far alignCoordSys (setToAlignCoordSys) has been the only one I've not been able to wrap my head around.
http://eigen.tuxfamily.org/
http://www.oonumerics.org/blitz/
http://tvmet.sourceforge.net/
pkohut
« Reply #7 on: June 04, 2010, 03:13:34 PM »
I've posted a question to this problem in the Eigen forum, hopefully someone will reply and say "Oh ya, just do this and that, bang."
In the meantime I found a working method using SysMat (http://pagesperso-orange.fr/jean-pierre.moreau/c_matrices.html), written in C.  I've got it converted and using the Eigen matrix library, just need to clean it up a bit more and switch it to use templates.
Thanks for heads up on what to look for guys, this has been a pretty fun research project.
gile
  • Marseille, France
« Reply #8 on: June 04, 2010, 04:03:19 PM »
Paul,
As far as I understand the method shown in the link you posted uses the Gauss Jordan elimination method as the LISP I posted up there.
pkohut
« Reply #9 on: June 04, 2010, 05:01:03 PM »
Paul,
Ya, they produce the same results.  :-)
pkohut
« Reply #10 on: June 04, 2010, 08:29:18 PM »
Thought it might interest some comparing Giles lisp version to a C++ version.  This version still needs some code refactoring done, for one it calcs column major instead of row major, hence the 2 transpose calls at the end.  Also, as written, the GaussJordanElimination function requires matrices 1 x 1 bigger than the input matrices, requiring extra matrix copying.  It's based on the SysMat function linked to in a earlier post.
Attached is a compile executable of the code below.
#include "stdafx.h"
#include <eigen\Eigen>
#include <iostream>
using namespace std;
template<class T, int NSize>
int GaussJordanElimination(Eigen::Matrix<T, NSize, NSize> & mm1, Eigen::Matrix<T, NSize, NSize> & mm2, T & det);
int _tmain(int argc, _TCHAR* argv[])
    double det;
    // Create 3 x 3 matrix and populate
    Eigen::Matrix<double, 3, 3> m1, m2;
    m1 << 1.0, 3.0, 0.0,
        5.0, 7.0, 0.0,
        10.0, 10.0, 1.0;
    m2 << 11.0, 13.0, 0.0,
        17.0, 19.0, 0.0,
        20.0, 5.0, 1.0;
    cout << "Calculating 3 x 3 Gauss Jordan Elimination" << endl;
    cout << "Input matrix m1" << endl << m1 << endl;
    cout << "Input matrix m2" << endl << m2 << endl;
    if(GaussJordanElimination<double, 3>(m1, m2, det)) {
        cout << "Gauss Jordan Elimination Calculated" << endl;
        cout << "Output matrix: Inverse m1" << endl << m1 << endl;
        cout << "Output matrix: Solution" << endl << m2 << endl;
        cout << "Output: Determinant = " << det << endl;
    else
        cout << "Gauss Jordan Elimination not computed" << endl;
    cout << endl;
    Eigen::Matrix<double, 4, 4> m3, m4;
    m3 << 1.0, 3.0, 5.0, 7.0,
        9.0, 11.0, 13.0, 17.0,
        19.0, 23.0, 29.0, 31.0,
        32.0, 34.0, 35.0, 36.0;
    m4 << 33.0, 37.0, 39.0, 41.0,
        43.0, 47.0, 49.0, 51.0,
        53.0, 57.0, 59.0, 71.0,
        72.0, 73.0, 74.0, 75.0;
    cout << "Calculating 4 x 4 Gauss Jordan Elimination" << endl;
    cout << "Input matrix m3" << endl << m3 << endl;
    cout << "Input matrix m4" << endl << m4 << endl;
    if(GaussJordanElimination<double, 4>(m3, m4, det)) {
        cout << "Output matrix: Inverse m3" << endl << m3 << endl;
        cout << "Output matrix: Solution" << endl << m4 << endl;
    else
    cout << endl;
    system("PAUSE");
    return 0;
template<int NSize>
inline void SetNaN(Eigen::Matrix<double, NSize, NSize> & m)
    m.fill(_Nan._Double);
template<int NSize>
inline void SetNaN(Eigen::Matrix<float, NSize, NSize> & m)
    m.fill(_Nan._Float);
    enum { nCols = NSize, mCols = NSize, };
    Eigen::Matrix<T, NSize + 1, 1> pc, pl, cs;
    pc.fill(0.0); pl.fill(0.0); cs.fill(0.0);
    // Create matrix +1 bigger than input matrix
    Eigen::Matrix<T, NSize + 1, NSize + 1> m1, m2;
    // Copy mm1 matrix to m1
    m1.block<NSize, NSize>(0, 0) = mm1;
    // fill last row and column with 0.0
    m1.row(NSize).fill(0.0);
    m1.col(NSize).fill(0.0);
    m2.block<NSize, NSize>(0, 0) = mm2;
    m2.row(NSize).fill(0.0);
    m2.col(NSize).fill(0.0);
    det = 1.0;
    for(int k = 0; k < nCols; ++k) {
        T pv = m1(k, k);
        int ik = k;
        int jk = k;
        T pav = fabs(pv);
        for(int j, i = k; i < nCols; ++i) {
            for(j = k; j < nCols; ++j) {
                if(fabs(m1(i, j)) > pav) {
                    pv = m1(i, j);
                    pav = fabs(pv);
                    ik = i;
                    jk = j;
            // Search terminated, the pivot is in location i=ik, j=jk
            // Memorizing pivot location;
            pc(k) = (T) jk;
            pl(k) = (T) ik;
            // Determinant det is actualised
            // If det = 0, error message and stop
            // Machine dependant EPSMACH equals here is 1e-20
            if(ik != k) det = -det;
            if(jk != k) det = -det;
            det = det * pv;
            if(fabs(det) < 1e-20) {
                SetNaN<nCols>(mm1);
                SetNaN<nCols>(mm2);
                return 0;
            // Positioning pivot in k,k
            if(ik != k)
                for(int i = 0; i < nCols; ++i) {
                    // exchange lines ik and k of matrix m1
                    T dTemp = m1(ik, i);
                    m1(ik, i) = m1(k,i);
                    m1(k,i) = dTemp;
                if(mCols) {
                    for(i = 0; i < mCols; ++i) {
                        T dTemp = m2(ik, i);
                        m2(ik, i) = m2(k, i);
                        m2(k, i) = dTemp;
                    // Pivot is a correct line
                    if(jk != k)
                        for(i = 0; i < nCols; ++i) {
                            // exchange columns jk and k of matrix m1
                            T dTemp = m1(i, jk);
                            m1(i, jk) = m1(i, k);
                            m1(i, k) = dTemp;
                        // Pivot is at correct column and is located in k,k
                        // Column k of matrix m1 is stored in cs vector
                        // then column k is set to zero.
                            cs(i) = m1(i, k);
                            m1(i, k) = 0.0;
                        cs(k) = 0.0;
                        m1(k,k) = 1.0;
                        // Line k of matrix m1 is modified
                        if(fabs(pv) < 1e-20) {
                            SetNaN<nCols>(mm1);
                            SetNaN<nCols>(mm2);
                            return 0;
                            m1(k,i) = m1(k,i) / pv;
                        if(mCols)
                                m2(k, i) = m2(k, i) / pv;
                        // Other lines of matrix m1 are modified
                        for(j = 0; j < nCols; ++j) {
                            if(j == k) j++;
                                // Line j of matrix m1 is modified
                                m1(j,i)= m1(j,i) - cs(j) * m1(k,i);
                            if(mCols)
                                    m2(j, i) = m2(j, i) - cs(j) * m2(k,i);
                        // Line k is ready
                } // mCols
    } // end of k loop
    // exchange lines
    for(int i = nCols - 1; i >= 0; --i) {
        int ik = (int) pc(i);
        if(ik == i)
            continue;
        // exchange lines i and pc(i) of matrix m1
        for(int j = 0; j < nCols; ++j) {
            T dTemp = m1(i,j);
            m1(i,j) = m1(ik,j);
            m1(ik,j) = dTemp;
        if(mCols) {
            for(int j = 0; j < mCols; ++j) {
                T dTemp = m2(i,j);
                m2(i,j) = m2(ik,j);
                m2(ik,j) = dTemp;
        // no more exchange is necessary
        // goto next line
    } // for i
    // exchange columns
    for(int j = nCols - 1; j >= 0; --j) {
        int jk = (int) pl(j);
        if(jk == j)
            continue;
        // exchange columns j et pl(j) of matrix m1
            T dTemp = m1(i,j);
            m1(i,j) = m1(i, jk);
            m1(i, jk) = dTemp;
        // No more exchange is necessary
        // go to next column
    // rearrangement terminated
    // for(int i = 0; i < )
    mm1 = m1.block<NSize,NSize>(0,0).transpose();
    mm2 = m2.block<NSize,NSize>(0,0).transpose();
    return 1;
pkohut
« Reply #11 on: June 05, 2010, 10:24:03 AM »
row (nth cnt mat)
Gile super nice code!  I'm trying to figure out its magic, but am unclear what this sort does (I see what it does, just don't know why).  Can you comment on that? TIA.
LE3
« Reply #12 on: June 05, 2010, 11:40:18 AM »
want to play... but this is as far I am now... let's see if the next part can be resolved to find the rotation matrix that will map one matrix onto another
hope am i right [added the resultant see if is right]:)
;;; matrix original
(setq a  1.0 b  3.0 c 0.0)
(setq d  5.0 e  7.0 f 0.0)
(setq g 10.0 h 10.0 i 1.0)
(setq det (- (* a (- (* e i) (* h f))) (+ (* b (- (* d i) (* g f))) (* c (- (* d h) (* g e))))))
;;; inverse from the original
(setq ia (/ (- (* e i) (* f h)) det))
(setq ib (/ (* (- (* b i) (* h c)) -1) det))
(setq ic (/ (- (* b f) (* e c)) det))
(setq id (/ (* (- (* d i) (* f g)) -1) det))
(setq ie (/ (- (* a i) (* g c)) det))
(setq _if (/ (* (- (* a f) (* d c)) -1) det))
(setq ig (/ (- (* d h) (* g e)) det))
(setq ih (/ (* (- (* a h) (* g b)) -1) det))
(setq ii (/ (- (* a e) (* b d)) det))
(setq invmat (list (list ia ib ic) (list id ie _if) (list ig ih ii)))
return: ((-0.875 0.375 0.0) (0.625 -0.125 0.0) (2.5 -2.5 1.0))
;; and to obtain the resultant rotation matrix by multiplying both matrices (the inverse by the final one):
;;; final matrix
(setq p 11.0 q  13.0 r 0.0)
(setq s 17.0 tt 19.0 u 0.0)
(setq v 20.0 w  5.0  x 1.0)
(setq rotMat
(list
  (list
(+ (* ia p) (* ib s) (* ic v))
(+ (* ia q) (* ib tt) (* ic w))
(+ (* ia r) (* ib u) (* ic x)))
  (list
(+ (* id p) (* ie s) (* _if v))
(+ (* id q) (* ie tt) (* _if w))
(+ (* id r) (* ie u) (* _if x)))
  (list
(+ (* ig p) (* ih s) (* ii v))
(+ (* ig q) (* ih tt) (* ii w))
(+ (* ig r) (* ih u) (* ii x)))))
return=((-3.25 -4.25 0.0) (4.75 5.75 0.0) (5.0 -10.0 1.0))
« Last Edit: June 05, 2010, 01:02:01 PM by LE3 »
pkohut
« Reply #13 on: June 05, 2010, 01:00:33 PM »
 :lol:
I've started converting Gile's to C++.  Just got done implementing the vl-sort-i routine. So that's about the line I'm on in his code.
LE3
« Reply #14 on: June 05, 2010, 01:04:51 PM »
he he... after giving a try (last night and a few hours today) ... it is not hard at all - end up being easy  :lol:
did my first part in C++ too, but as noticed for a 3x3 matrix - but it can easy to add another column and row...
 :lol:
