Author Topic: how to move a face in a solid ?  (Read 12686 times)
ahlzl
Re: how to move a face in a solid ?
« Reply #15 on: June 20, 2010, 10:47:00 AM »
Wrapper to C#, Success!(CAD2008 + VS2005)
step1: Create a new ARX project
step2: Add a class: MyClass
step3: In MyClass.h, Add code:
#include "tchar.h"
step4: In MyClass.cpp, Add code:
extern "C" __declspec(dllexport) AcDb3dSolid* GetSubentIndexs()
AcDbObjectId entId = NULL;
AcArray<AcDbSubentId*> subIdArr;
AcEdSolidSubentitySelector subSel;
AcDb3dSolid *pSolid3d = NULL;
if (subSel.selectFaces(entId, subIdArr) == Acad::eOk)
acdbOpenObject(pSolid3d, entId, AcDb::kForWrite);
TCHAR subIdIndexStrs[1000];
TCHAR indexStr[10];
int index = 0;
for (int i = 0; i < subIdArr.length(); i++)
index = (int)(subIdArr[i]->index());
_itow(index, indexStr, 10);
if (i == 0)
wcscpy(subIdIndexStrs, indexStr);
else
wcscat(subIdIndexStrs, _T("-"));
wcscat(subIdIndexStrs, indexStr);
struct resbuf rb;
rb.restype = RTSTR;
rb.resval.rstring = subIdIndexStrs;
acedSetVar(_T("users1"), &rb);
return pSolid3d;
return NULL;
step5: Compile, Generate *.arx file.
step6: copy the file to AutoCAD Support Directory
strp7: Create a new C# project, Add code
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Colors;
namespace Cs
    public class Class1
        [DllImport("yourARX.arx", CallingConvention = CallingConvention.Cdecl, EntryPoint = "GetSubentIndexs")]
        public static extern IntPtr GetSubentIndexs();
        [CommandMethod("test")]
        public void MyTest()
            Color myColor = Color.FromColorIndex(ColorMethod.ByLayer, 1);
            IntPtr rb = GetSubentIndexs();
            if (rb != IntPtr.Zero)
                Solid3d solid3dEnt = DisposableWrapper.Create(typeof(Solid3d), rb, true) as Solid3d;
                if (solid3dEnt != null)
                    string users1Value = (string)Application.GetSystemVariable("users1");
                    String[] strs = users1Value.Split(new char[] { '-' });
                    for (int i = 0; i < strs.Length; i++)
                        SubentityId subId = new SubentityId(SubentityType.Face, Convert.ToInt16(strs[i]));
                        solid3dEnt.SetSubentityColor(subId, myColor);
                    solid3dEnt.Close();
It's Alive!
  • Retired
  • AKA Daniel
« Reply #16 on: June 20, 2010, 07:28:47 PM »
Good start! a couple of small issues, first,  in the ARX you have a memory leak at subIdArr, you need to iterate the array and delete the pointers, Second you pass an object that's opened for write,  when you should probably pass an ObjectID  :-)
ahlzl
« Reply #17 on: June 20, 2010, 09:20:39 PM »
Very grateful to the guidance of Daniel!
First Problem,Is this it?
static void ahlzlArxProject1_MyCommand1(void)
// Add your code for command ahlzlArxProject1._MyCommand1 here
AcDbEntity *pEnt;
AcDb3dSolid *pSolid3d;
if (acdbOpenAcDbEntity(pEnt, entId, AcDb::kForWrite) == Acad::eOk)
pSolid3d = (AcDb3dSolid*)pEnt;
AcDbSubentId subId(AcDb::kFaceSubentType, subIdArr[i]->index());
pSolid3d->extrudeFaces(subIdArr, 100.0, 0.0);
[color=red]delete subIdArr[i][/color];
pSolid3d->close();
TCHAR indexStr[10];
int index = 0;
if (i == 0)
else
[color=red]delete subIdArr[i];[/color]
struct resbuf rb;
rb.restype = RTSTR;
return pSolid3d;
return NULL;
« Last Edit: June 20, 2010, 09:23:44 PM by ahlzl »
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: June 20, 2010, 10:24:29 PM »
I might do something like this (untested) see attachment
.h
#pragma managed
#pragma once
using namespace System;
using namespace System::Text;
using namespace Autodesk::AutoCAD::DatabaseServices;
using namespace Autodesk::AutoCAD::Geometry;
using namespace Autodesk::AutoCAD::Runtime;
inline Autodesk::AutoCAD::DatabaseServices::SubentityId ToSubentityId(const AcDbSubentId& id)
  Autodesk::AutoCAD::DatabaseServices::SubentityId ret;
  GETSUBENTITYID(ret) = id;
  return ret;
namespace AcMgdWrprs
  public ref class Utilities
    static bool SolidSubentitySelector([Out]ObjectId %solid,[Out]array<SubentityId> ^%sids);
.cpp
#include "StdAfx.h"
#include "Utilities.h"
using namespace System::Collections::Generic;
using namespace Autodesk::AutoCAD::EditorInput;
using namespace Autodesk::AutoCAD::ApplicationServices;
  Utilities::Utilities(void)
  bool Utilities::SolidSubentitySelector( [Out]ObjectId %solid,[Out]array<SubentityId> ^%sids )
      sids = gcnew array<SubentityId>(subIdArr.length());
        AcDbSubentId *sid = subIdArr[i];
        sids[i] = ToSubentityId(*sid);
        delete sid;
      solid = ToObjectId(entId);
      return true;
    return false;
It's Alive!
  • Retired
  • AKA Daniel
« Reply #19 on: June 20, 2010, 10:33:34 PM »
C#
namespace ExecMethod
  public class Commands
    [CommandMethod("doit")]
    static public void test()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      SubentityId[] sids;
      ObjectId id;
      if(AcMgdWrprs.Utilities.SolidSubentitySelector(out id, out sids))
        ed.WriteMessage("\n{0}", id);
        foreach (SubentityId sid in sids)
          ed.WriteMessage("\n{0}", sid.Index);
It's Alive!
  • Retired
  • AKA Daniel
« Reply #20 on: June 20, 2010, 10:55:56 PM »
here is extrudeFaces
bool Utilities::SolidExtrudeFaces( double width, double taper )
      AcDbObjectPointer<AcDb3dSolid> spr(entId,AcDb::kForWrite);
      spr->extrudeFaces(subIdArr,width,taper);
        delete sid;
      return true;
    return false;
      if (AcMgdWrprs.Utilities.SolidExtrudeFaces(10, 0))
It's Alive!
  • Retired
  • AKA Daniel
« Reply #21 on: June 20, 2010, 10:57:32 PM »
doh, I see that was already in the API  :laugh:
ahlzl
« Reply #22 on: June 20, 2010, 11:11:54 PM »
Daniel is too great!
I would like to come to Shanghai (I was born in Shanghai),When to ask for Danie ARX,But I do not speak English! :oops: :oops: :oops:
SEANT
« Reply #23 on: June 21, 2010, 04:11:16 AM »
Thanks for the effort guys.  When I do make the jump, the study material here - and the other forum sections - will undoubtedly make the water more inviting. :-)
It is in the .NET API,  but the method appeared to be setup incorrectly (AutoCAD 2009).  I'll look through these later posts for clues to a straight .NET solution.  I certainly wouldn't be surprised if I missed something on my first go.
Sean Tessier
AutoCAD 2016 Mechanical
