Author Topic: Setting up tooltips for MFC controls  (Read 4616 times)
It's Alive!
  • BricsCAD
  • AKA Daniel
« on: June 02, 2010, 01:29:09 AM »
the first thing you need to do is handle TTN_NEEDTEXT
I.e.
ON_NOTIFY_EX(TTN_NEEDTEXT,0,&YourClass::OnToolNeedText)
then add your member function, note the docs say TTN_NEEDTEXT handlers can ignore the pResult parameter, so I do.
here's a sample
BOOL CBlockManagerTabDlg::OnToolNeedText( UINT id, NMHDR* pNMHDR, LRESULT* pResult )
  if(pNMHDR)
    //get the resource ID from sender
    UINT nID = ::GetDlgCtrlID((HWND)pNMHDR->idFrom);
    LPTOOLTIPTEXT lpTTT = (LPTOOLTIPTEXT)pNMHDR;
    //is window handle to the tool
    if ( !(lpTTT->uFlags & TTF_IDISHWND) )
      return FALSE;
    CToolTipCtrl* pToolTip = ::AfxGetModuleThreadState()->m_pToolTip;
    if (!pToolTip)
      return FALSE;
    //magically enables \r\n
    pToolTip->SetMaxTipWidth(SHRT_MAX);
    //init ptr
    LPCTSTR lpszTipMsg = NULL;
    //add our text(TCHAR[80] max) when we find our resource ID
    switch(nID)
    case IDC_BUTTON_DSK_TOP:
        lpszTipMsg = _T("Go to Desktop Folder");
      break;
    case IDC_BUTTON_HOME:
        lpszTipMsg = _T("Go to Default Folder");
      break;
    case IDC_BUTTON_MY_DOC:
        lpszTipMsg = _T("Go to My Documents Folder");
      break;
    case IDC_LIST_BLKICON:
        pToolTip->CenterWindow(CWnd::FromHandle((HWND)pNMHDR->idFrom));
        lpszTipMsg = _T("Double Click or Drag a block to insert");
      break;
    case IDC_TREE_FLDR:
        lpszTipMsg = _T("Double Click to insert\r\nDrag to open\r\nRight Click Folder to set as default");
      break;
    } //switch
    if(!lpszTipMsg)
      return FALSE;
    //copy buf to tooltip
    ::lstrcpyn(lpTTT->szText,lpszTipMsg,sizeof(lpTTT->szText));
  return TRUE;
« Last Edit: June 02, 2010, 01:32:53 AM by Daniel »
frtfff
Re: Setting up tooltips for MFC controls
« Reply #1 on: June 02, 2010, 04:25:36 AM »
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #2 on: September 08, 2010, 10:00:14 PM »
So I can find it later  :laugh:
For palettes use
ON_NOTIFY_EX_RANGE(TTN_NEEDTEXT,0,0xFFFF,&CPalette***ChildDlg::OnToolNeedText)
this->EnableToolTips(TRUE);
