Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
Code Red
AutoLISP (Vanilla / Visual)
Topic:
? Remove Support File Search Path ?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ? Remove Support File Search Path ? (Read 1933 times)
Oak3s
Guest
on:
June 01, 2010, 07:59:15 PM »
Is it possible to REMOVE a path from the Support File Search Path via lisp? How?
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: ? Remove Support File Search Path ?
Reply #1 on:
June 01, 2010, 08:36:30 PM »
http://www.theswamp.org/index.php?topic=33548.msg389256#msg389256
Logged
Oak3s
Guest
Reply #2 on:
June 01, 2010, 10:04:12 PM »
ahhhh
Thank you.
What resource should I look to for documentation on these Visual Lisp functions. Maybe I am not using HELP (F1) correctly.
Again, thank you. Just what I was looking for.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Code Red
Topic:
