Stig,
It looks like that the 64 bit has been dropped somewhere along th line. This is from R13 help files
BLOCK group codes
Group codes Description
5 Handle
100 Subclass marker (AcDbEntity)
8 Layer name (fixed)
100 Subclass marker (AcDbBlockBegin)
2 Block name
70 Block-type bit-coded flags
1 = This is an anonymous block generated by hatching, associative dimensioning, other internal operations, or an application
2 = This block has attribute definitions
4 = This block is an external reference (xref)
8 = This block is an xref overlay
16 = This block is externally dependent
32 = This is a resolved external reference, or dependent of an external reference (ignored on input)
64 = This definition is referenced (ignored on input)
10 DXF: X value of block base point Application: Block base point
20, 30 DXF only: Y and Z values of block base point
3 Block name
1 Xref path name (if the block is an xref) (optional)
Copyright (c) 1995 Autodesk, Inc.
-David
