Author Topic: Using a field with filename - path only  (Read 14028 times)
KOWBOI
Re: Using a field with filename - path only
« Reply #60 on: November 01, 2010, 05:23:24 PM »
The startup still didn't force a regen when opening a drawing using this code. I'm stumped.
« Reply #61 on: November 01, 2010, 05:45:20 PM »
what happens if you place the same field manually?
