Author Topic: Why macro name asking for opening the drawings in AutoCAD?  (Read 2094 times)
BEENA
When am I going to open the drawings in AutoCAD asking Macro name, then the command line is not active. So I want to use toolbar command to close the drawings that is why I can not open 2 drawings in same time !
Anybody knows please help
Hangman
Re: Why macro name asking for opening the drawings in AutoCAD?
« Reply #1 on: June 01, 2010, 03:51:25 PM »
If I'm understanding this correctly, you cannot open more than one drawing at a time, and your getting dialog box when you want command line capabilities.?.
Check your SDI system variable.  If it's set at 1 (one) then you are in Single Document mode, set it to zero.
Also check your FILEDIA system variable.  If it's set to zero, you will get command line activity, if it's set to 1 (one) you will get dialog box activity.
I hope this answers your question.
Hangman  8)
