Author Topic: VB.NET Evaluation of a VB.net Expression  (Read 24628 times)
Re: VB.NET Evaluation of a VB.net Expression
« Reply #15 on: May 31, 2010, 12:19:55 PM »
I don't have an example, but theoretically it should be possible. Presuming the wrapper is a predefined function that merely holds the code.
If you always use the same wrapper name you can always unload that wrapper function could you not?
Peter Jamtgaard
« Reply #16 on: May 31, 2010, 04:14:47 PM »
Keith,
I have been playing with an alternate to the netload command line command.
I am interested in capturing the wrapper, as I mentioned.
Is this a good place to start or should I use that something similar to the
code shown on eggheadcafe referenced above?
Peter
<LispFunction("Netload")> _
    Public Function Netload(ByVal rbfNetAssemblyFile As ResultBuffer) As ResultBuffer
        Dim rbfReturn As New ResultBuffer
        Try
            Dim arrNetAssemblyFile As TypedValue() = rbfNetAssemblyFile.AsArray()
            System.Reflection.Assembly.LoadFrom(arrNetAssemblyFile(0).Value.ToString)
            return Nothing
        Catch
            rbfReturn.Add(New TypedValue(&H138D, "Catch Error"))
            Return rbfReturn
        End Try
    End Function
« Reply #17 on: May 31, 2010, 06:42:44 PM »
After revisiting the code at eggheadcafe, you will note that is writes the class on the fly and then compiles it and executes the function EvalCode The wrapper itself would necessarily have to be the evaluator. You could netload the evaluator and send it the string to evaluate, but it won't help you in the IDE. Presumably you want to execute .Net functions in lisp (as evidenced by your function above).
Why build your function around the code provided, netload it, and pass to it the string needed to be evaluated. Presumably the arbitrary class would be self depreciating when the class is disposed, thus unloading it wouldn't be necessary. It would require some testing to be sure, but based on what I've seen, it could be really cool to introduce some .net functionality to lisp.
When I get time, I think I will look into this a bit more.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: May 31, 2010, 11:16:05 PM »
@ Peter
you should test arguments to see if they are null
you should return true on success and nil on error. the way you have it now, you're returning nil on success and a list on failure.
IMO, When interacting with lisp, you should try you make your functions behave as a lisp function would
It's Alive!
  • Retired
  • AKA Daniel
« Reply #19 on: May 31, 2010, 11:38:02 PM »
something like this
    // going to return nil or 1, I think one of the
    // cad versions had a bug with with T
    [LispFunction("LOADNET")]
    public static object LoadNetModule(ResultBuffer args)
      try
        if(args == null )  return null;
        TypedValue[] tvs = args.AsArray();
        if (tvs.Length == 0)  return null;
        TypedValue arg = tvs[0];
        if (arg.TypeCode != (int)LispDataType.Text) return null;
        string file = arg.Value as string;
        if (string.IsNullOrEmpty(file)) return null;
        System.Reflection.Assembly.LoadFrom(file);
        return 1;
      catch
        return null;
« Reply #20 on: June 01, 2010, 04:36:13 AM »
ok, I'll play ...
How do you load that after it's compiled into an assembly ??
It's Alive!
  • Retired
  • AKA Daniel
« Reply #21 on: June 01, 2010, 05:13:35 AM »
ok, I'll play ...
Sorry, I should have posted in this thread
http://www.theswamp.org/index.php?topic=33538.0
« Reply #22 on: June 01, 2010, 05:18:43 AM »
ok, I'll play ...
OK, no hassles ..
but somewhere you'd still need a NETLOAD, yes ??
.. and I don't see a problem with using netload, but perhaps I've missed some part of the discussion.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #23 on: June 01, 2010, 05:24:08 AM »
ok, I'll play ...
.... I've missed some part of the discussion....
I think that was me, I'll go back an play in my ARX sinkhole  :laugh:
« Reply #24 on: June 01, 2010, 05:28:07 AM »
oh yeah, that's right ... take your ball and run away and play with Paul  :-D
« Reply #25 on: June 01, 2010, 06:29:31 AM »
footnote:
If [you] paid attention to the API wishlist @  http://through-the-interface.typepad.com/through_the_interface/2010/05/theres-still-time-to-fill-out-the-2010-api-wishlist-surveys.html
you'll notice that C# scripting (as well as an enhanced VLIDE) is scoring high on the voting.
... though we'll need to wait to see what action is taken regarding the items on the list.
further footnote :
Peter, how'd you go with your submission for a course at AU this year ??
sinc
« Reply #26 on: June 01, 2010, 08:22:00 AM »
How funny.  I wouldn't use the word "cool" to describe Lisp.Net...  Maybe "cringe-worthy"...  Or maybe just "ugh"...   :-)
« Reply #27 on: June 01, 2010, 08:24:38 AM »
I suppose its a good thing that you don't make all the rules ... or that any one person doesn't .. it would be a pretty dull place to live
It's Alive!
  • Retired
  • AKA Daniel
« Reply #28 on: June 01, 2010, 08:37:52 AM »
I think  L# would have been really cool especially with .NET4, too bad it's not being maintained.
sinc
« Reply #29 on: June 01, 2010, 11:33:35 AM »
Sometimes I really wonder about the posts I read here...  Some of them get pretty far out there.
