Author Topic: reinvent the wheel  (Read 7607 times)
David Hall
  • Automatic Duh Generator
Re: reinvent the wheel
« Reply #30 on: July 09, 2010, 12:45:23 PM »
Glenn, I am studying your code from the plugin, and it looks like you are writing the XRecords in the current dwg db, is that right?
« Last Edit: July 09, 2010, 01:07:56 PM by CmdrDuh »
Glenn R
« Reply #31 on: July 09, 2010, 01:46:01 PM »
Duh,
There's no other place to write them to really, or did you mean that I'm writing them to drawing objects and NOT the land of NOD?
If so, then yes, in XrefStates I wrote them to each blockTableRecord that was an xref. That way, AutoCAD handles the redundancy for me eg. when an xref is detached, the BTR is no longer there, so I don't have to update a master list somewhere else and possibly run the risk of having it get out of sync.
Make sense?
David Hall
« Reply #32 on: July 09, 2010, 01:50:01 PM »
makes sense, and I think you answered my question.  I need to figure out another way to store the number
dgorsman
« Reply #33 on: July 09, 2010, 01:54:56 PM »
For drawing-level data, I create an application-specific dictionary under the NOD.  If necessary, I add another layer or two of dictionaries under that, just to keep the XRECORDS organized.  Object-specific data works the same way, with the application-specific dictionary located under the objects extension dictionary.  This way I don't accidentally hose another applications data, reduces the chance of others buggering with mine, and it keeps my own data organized.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
David Hall
« Reply #34 on: July 10, 2010, 12:30:59 PM »
I was thinking that either I will have to use an attribute to store the width factor, or figure out some other way.
