Oops, fogot about that part, Mike. For some reason the Dataextraction saves the file in UTF-8 format. Open it with Notepad or wordpad, use SaveAs and make sure to change the Encoding type to ANSI.
Jeff,
Thanks for the key to bliss.... Well, I got the original problem with VBA solved. It seems that I had a vba program loading in one of my
lisp routines, and the people that worked on my dwgs lately had a block that they applied some sort of VBA something to. I purged
them and updated my lisp routine by erasing the "vbaload" routine and it all opens fine now, but I did get a note from Richard (Sinc) that
there are some Sub-assemblies and pipe networks that can also do the Nag pop-ups. So, there you go. After days of some work and a whole
lot of help from here I have my answers. Again many thanks for these latest solutions.
A footnote about Surfaces and point clouds and using over 8 millions points (6 Lidar panels) in point cloud to make a surface that ended up only being
33 meg when processed, that was fast and very cool. The extraction from dxf was a bit time consuming using (x,y,z format)(6 Lidar panels with over
890000 nodes/each) , but worked flawlessly. I was also able to make a xml of this surface in 2011 and import the xml into 2010.
MJP
