Author Topic: Ghostscript fonts in PDF  (Read 3951 times)
« on: May 14, 2010, 11:01:29 AM »
When creating pdf's from Ghostscript is there a way to make the text in the drawing text in the pdf? The ACAD pdf plotter can do this, when it works.
The reason behind this is for searching.
thanks
Re: Ghostscript fonts in PDF
« Reply #1 on: May 14, 2010, 11:38:51 AM »
thanks
We are all searchiing Mark.....
try this  http://stat.ethz.ch/R-manual/R-patched/library/grDevices/html/embedFonts.html
Peter
« Reply #2 on: July 06, 2010, 05:54:24 PM »
When creating pdf's from Ghostscript is there a way to make the text in the drawing text in the pdf? ...
Which fonts are you using in AutoCAD: SHX or TTF?
Peter
