Author Topic: Multileader: Move but keep original placement of leader points  (Read 5029 times)
alanjt
  • Standby for witty remark...
I needed/wanted a way to select a MLeader with additional objects around it (text, lines marking through text in MLeader, etc.), move to new location but keep original placement of leader points.
I scratched this out last night and tested in '08 to find that it worked perfectly. However, when I got to work today and tested it in '09, it refused to entmod my Multileader.
The extraction data still works to retrieve each leader end point, but I can't make it entmod in '09. Without this option, it's garbage to me. Thought I'd share the data anyway...
;;;( (lambda (lst n)
;;;    (vl-remove nil
;;;      (mapcar
;;;        (function
;;;          (lambda (x)
;;;            (setq n (1+ n))
;;;            (if (and (eq (car x) 10)
;;;                     (eq (cdr (nth (1- n) lst)) "LEADER_LINE{"))
;;;              (cons n (AT:DrawX (cdr x) 1))))) lst)))
;;;  (entget (car (entsel)))
;;;  -1)
;;;      (mapcar
;;;        (function
;;;          (lambda (x)
;;;            (setq n (1+ n))
;;;  -1)
(defun c:Test (/ ss p1 p2 lst)
  (and (setq ss (ssget "_:L" '((0 . "MULTILEADER,LINE,TEXT,MTEXT,LWPOLYLINE"))))
       (setq p1 (getpoint "\nSpecify base point: "))
       (if acet-ss-drag-move
         (setq p2 (acet-ss-drag-move ss p1 "\nSpecify second point: " T))
         (setq p2 (getpoint p1 "\nSpecify second point: "))
       ((lambda (i)
          (while (setq e (ssname ss (setq i (1+ i))))
            (if (eq "MULTILEADER" (cdr (assoc 0 (entget e))))
              (setq lst ((lambda (lst n)
                           (mapcar
                             (function
                               (lambda (x)
                                 (setq n (1+ n))
                                   x
                             lst
                          (entget e)
                          -1
            (vla-move (vlax-ename->vla-object e)
                      (vlax-3d-point (trans p1 1 0))
                      (vlax-3d-point (trans p2 1 0))
            (and lst
                 (entmod
                   (mapcar
                     (function
                       (lambda (a b)
                         (if a
                           a
                           b
                     lst
                     (entget e)
         -1
Dropbox
butzers09silverado
Re: Multileader: Move but keep original placement of leader points
« Reply #1 on: May 06, 2010, 12:21:23 PM »
I'd like the mleader to treat text of different annotative scales differently so that 20 scale mtext isn't jammed up at 40scale... but no, you move around the 40 scale and fix it and then your 20 scale is also screwed up....
did you end up getting this to work in 09'.... interested.
alanjt
« Reply #2 on: May 06, 2010, 01:00:22 PM »
Move the text by grip editing, not the MOVE command and it won't alter alternate scales.
You ask this question less than 30 minutes after I post my data. :lmao: I'll continue to play with it some, but I'm not sure what else I can do. I'd love for someone else to test it in '09 or above.
Dropbox
« Reply #3 on: May 06, 2010, 01:12:13 PM »
Does it error in '09 or maybe an entupd might help?  :|
alanjt
« Reply #4 on: May 06, 2010, 01:14:56 PM »
First thing I tried was entupd.  :| Excellent suggestion.
No error, just doesn't update.
Dropbox
« Reply #5 on: May 06, 2010, 01:16:13 PM »
Worked here in '09.  Single mleader entity with an mtext entity attached to it.  I selected both, and moved them, but the leader still pointed to the same spot.  Which is how I think you wanted it to work.
alanjt
« Reply #6 on: May 06, 2010, 01:20:32 PM »
Damnit! At least this tells me there's hope.
Thanks Tim.
Dropbox
« Reply #7 on: May 06, 2010, 01:23:49 PM »
You're welcome.  I don't use mleaders, so I'm not sure of the use of them, so if you want to post a drawing that doesn't work for you, I can test, and let you know what happens.  Maybe you set them up a different way, and it a setting that is messing with the code.
alanjt
« Reply #8 on: May 06, 2010, 01:29:28 PM »
Thank Tim. I just WBlocked out one object. I opened it to check and it still doesn't work.
Dropbox
alanjt
« Reply #9 on: May 06, 2010, 01:37:33 PM »
I forgot to mention; I'm running Civil 3D 2009. I tested it on other workstations here and it still doesn't work. I rarely do this kind of work. I think I'll just stick with QLeaders for that next random occasion.
Dropbox
« Reply #10 on: May 06, 2010, 01:51:00 PM »
That one didn't work for me either.  I'm on '09 Electrical.  I'll see if I can spot a difference between the two when I get time.
alanjt
« Reply #11 on: May 06, 2010, 01:52:19 PM »
How odd. Also, if you get a chance, shoot me an example of one you got to work.
Dropbox
« Reply #12 on: May 06, 2010, 02:16:48 PM »
I wonder if it is because the one you have is annotative?  Just an idea, as it has a point of the leader line also.
The two white ones, are the ones I drew.
alanjt
« Reply #13 on: May 06, 2010, 02:19:41 PM »
Ah hah! That's exactly what the problem is; won't work if Annotative. Of course, this only gives me a reason, not a solution. Oh well, good thing I'd probably never use it after today anyway. Thanks Tim. :) It was a useful exercise, none-the-less.
Dropbox
« Reply #14 on: May 06, 2010, 02:26:53 PM »
That is the solution.  I change the leader line point in the annotation part, then changed the point of the leader line in the mleader section, and the point undated.
You're welcome Alan.  It's nice to actually find an answer to a problem.
