Author Topic: lisp to check drawing for elements with a z vlaue (ie not flattened)  (Read 5780 times)
Pad
Re: lisp to check drawing for elements with a z vlaue (ie not flattened)
« Reply #15 on: May 14, 2010, 07:45:10 AM »
thanks dvarino
i think the problem is now with this cond statement:
   ((= superf "Yes") (prompt "\n Running SUPERFLATTEN, back-up of drawing will be saved with PREFLAT prefix) (SAVE_PREFLAT))
   ( (or (= superf "No") (= superf "") (prompt "\n OK, moving on and leaving drawing as is in 3D...")))
) ; end cond
but I'm damned if I can figure it out.. :|
save_preflat being this:
;SAVE_PREFLAT = save copy of drawing as preflat-state
(defun SAVE_PREFLAT ()
(setq AcadObj (vla-get-ActiveDocument (vlax-get-acad-object)))
  (setq File_PreName "PREFLAT-")
  (setq FileName (getvar "DWGNAME"))
  (setq PreFileName (getfiled "Input name of PREFLATTENING drawing to save" (strcat File_PreName FileName) "dwg" 1))
  (if (findfile PrefileName)
    (command "_SAVE" PreFileName "Y")
    (command "_SAVE" PreFileName)
  (princ (strcat "\n" File_PreName "File saved as '" (vl-filename-base PreFileName) "'.\n"))
   (c:superflatten)
V-Man
« Reply #16 on: May 14, 2010, 07:57:10 AM »
Ok, try this out.
(defun c:CZ (superf)
  (command "zoom" "extents")
  (command "_-view" "_top")
;(command "regenall")
  (initget 1 "Yes No  ")
    (and
      (equal 0.0 (caddr (getvar "extmin")) 1e-6)
      (equal 0.0 (caddr (getvar "extmax")) 1e-6)
     (princ "\n*** Drawing is flat (2D), continuing on... ***")
     (setq superf
    (getkword
      "\n*** Drawing contains 3D elements *** Would you like to run SUPERFLATTEN? [Yes/<No>]:"
  (setq superf "No")
  (if (not superf)
    (setq superf "No")
  (if (= superf "Yes")
      (SAVE_PREFLAT)
  ) ;if
  (if (= superf "No")
      (prompt
  ) ;if
) ;end defun
;SAVE_PRE = save copy of drawing as preflat-state
  (setq PreFileName
   "dwg"
   1
  (princ (strcat "\n"
File_PreName
"File saved as '"
"'.\n"
  (c:superflatten)
V-Man
« Reply #17 on: May 14, 2010, 08:06:09 AM »
Third try is the charm
This should work for you..
(defun c:CZ ( / superf);fixed
    (and
     (setq superf
    (getkword
  (if (not superf)
    (setq superf "No")
      (SAVE_PREFLAT)
  ) ;if
  (if (= superf "No")
      (prompt
  ) ;if
) ;end defun
  (setq PreFileName
   "dwg"
   1
  (princ (strcat "\n"
File_PreName
"File saved as '"
"'.\n"
  (c:superflatten)
Pad
« Reply #18 on: May 14, 2010, 08:21:13 AM »
That's the one fantastic.  When I have a bit more time I will properly look at your code. Thank you very much!
one quick question though.
Command: CZ
Command:
 OK, moving on and leaving drawing as is in 3D...nil
as the drawing is flat i don't want the 'OK, moving on and leaving drawing as is in 3D...nil' message to be displayed.
the intention when the drawing is flat is a clean exit, instead of carrying on to the superf part.
could i just add to this line
     ((princ "\n*** Drawing is flat (2D), continuing on... ***") (setq superf flat))
and then add below that
  (if (= superf "Flat")
many thanks
edit:  just tried it and the answer is no..
« Last Edit: May 14, 2010, 08:25:45 AM by Pad »
V-Man
« Reply #19 on: May 14, 2010, 09:14:16 AM »
Try this...
    (and
     ;(princ "\n*** Drawing is flat (2D), continuing on... ***")
     (setq superf
    (getkword
   (if (not superf) (setq superf "No"))
      ((= superf "Yes")(SAVE_PREFLAT))
            (if (= superf "N0")
   );if
) ;end defun
  (setq PreFileName
   "dwg"
   1
  (princ (strcat "\n"
File_PreName
"File saved as '"
"'.\n"
  (c:superflatten)
Pad
« Reply #20 on: May 14, 2010, 09:29:02 AM »
absolutely perfect thank you so much  :-)
will give it a good going over very shortly.
so pleased to get this working, cheers
« Last Edit: May 14, 2010, 10:04:09 AM by Pad »
