I have an issue that seems to break many command routines.
If a dimension style is set to annotative in the current drawing or XREF it seems to error out the lisp routines.
So I have been looking around to see if anyone has found a programmatic solution to remove (uncheck the box on the Fit tab of Modfiy> DIMSTYLES)
for all dimension styles. So far I have found nothing about it anywhere and I am beginning to wonder if it is even possible?
Has anyone else ran into this problem?
:ugly:
