Author Topic: Remove Annotative setting from all dimensions in a file?  (Read 1910 times)
KewlToyZ
« on: May 05, 2010, 11:52:58 AM »
I have an issue that seems to break many command routines.
If a dimension style is set to annotative in the current drawing or XREF it seems to error out the lisp routines.
So I have been looking around to see if anyone has found a programmatic solution to remove (uncheck the box on the Fit tab of Modfiy> DIMSTYLES)
for all dimension styles. So far I have found nothing about it anywhere and I am beginning to wonder if it is even possible?
Has anyone else ran into this problem?
 :ugly:
Re: Remove Annotative setting from all dimensions in a file?
« Reply #1 on: May 05, 2010, 12:05:35 PM »
I would say change the code instead of changing the drawing.
/opinion
« Reply #2 on: May 05, 2010, 12:41:49 PM »
I dont see how the two are even related.
