ok here is the example of the rack.
http://www.theswamp.org/screens/AVCAD/RACK.jpgHope it is good enough if not I will post more.
This was an 85" rack. It has 45 Panel spaces.
They are 1.75" in height each (1 unit high) and they are 19" in length.
Text should be in all CAP'S. For now let the Charaters rest at the max. The Tags that will be in these shold be nothing more then...
DVD
AMP
VCR/DVD
CATV
SERVER
so I dont think it will be a problem.
Here is an example with the Side Panels and Rack Scales attached.
http://www.theswamp.org/screens/AVCAD/RACK1.jpg******************
Side panels are not Split or even panels that reside inside the rack. They are actually a peice of equipment attached to the side of the rack to allow for ventalation and cable paths.
It would actually be a seperate vlock that gets attached to the rack. (see picture)
Scale agian is seperate block attached to the rack. This block is for ease of counting Units heights. (see Picture)
So those two yes/no options would be for the entire block. Selecting yes would attach those two or one block when you hit ok. Or I would like it to atleast.
If that doesnt clear that up I will try again.
I was mistaken in my post.
HEIGHT OF PANEL SELECTIONS:
1 TO 30
1 TO 9 - 2 WAY SPLIT
1 TO 9 - 3 WAY SPLIT
Should read:
1 TO 12 - ALL HAVE FULL IN ADDITION TO FOLLOWING
1 TO 10 - 2 WAY SPLIT
1 TO 10 - 3 WAY SPLIT
11 TO 12 - ARE ONLY FULL NO SPLITS
So Height of Panel can go up to 12 ( 1 2 3 4 5 6 7 8 9 10 11 12 )
Within the Height of Panel Drop down it should have Multiple selections
1 - Full
1 - 2 way split
1 - 3 way split
2 - Full
2 - Full - 2 Line of text
2 - 2 way split
2 - 2 way split - 2 line of text
2 - 3 way split
2 - 3 way split - 2 line of text
3 - Full
3 - Full - 2 Line of text
3 - Full - 3 Line of text
3 - 2 way split
3 - 2 way split - 2 line of text
3 - 2 way split - 3 line of text
3 - 3 way split
3 - 3 way split - 2 line of text
3 - 3 way split - 3 line of text
(3 thru 12 will be the same)
I think we get the point there will be a lot of selections.
OK....Now when...lets say
3 - 2 way split - 3 line of text ....... is selected
This would mean that there would be a:
Left and Right Text area availble with 3 line of text each
If
3 - Full - 3 Line of text ....... is selected
this would mean that there would be:
1 text area availble with 3 lines of text
Hope this helps.
