ok i hopfully this works....
http://www.theswamp.org/screens/AVCAD/Drawing1-Model.plt.jpgNUMBER OF PANELS SHOWN SHOULD BE LINKED TO HEIGHT OF RACK IN FIRST SELECTION.
51" RACK IS SELECTED ONLY 25 PANELS ARE AVAILBLE
60" RACK IS SELECTED ONLY 30 PANELS ARE AVAILBLE
68" RACK IS SELECTED ONLY 35 PANELS ARE AVAILBLE
77" RACK IS SELECTED ONLY 40 PANELS ARE AVAILBLE
84" RACK IS SELECTED ONLY 45 PANELS ARE AVAILBLE
HEIGHT OF PANEL SELECTIONS:
1 TO 30
1 TO 9 - 2 WAY SPLIT
1 TO 9 - 3 WAY SPLIT
TEXT INPUT SELECTIONS:
IF PANEL HEIGHT IS = 1 THEN 1 TEXT LINE AVAILBLE
IF PANEL HEIGHT IS = OR > 2 THEN 2 TEXT LINE AVAILBLE
IF PANEL HEIGHT IS = OR > 3 THEN 3 TEXT LINE AVAILBLE
IF PANEL HEIGHT IS = OR > 4 THEN 4 TEXT LINE AVAILBLE
TEXT INPUT SELECTIONS: FOR 2 WAY SPLIT PANELS
IF PANEL HEIGHT IS = 1 THEN 1 TEXT LINE AVAILBLE (LEFT,RIGHT)
IF PANEL HEIGHT IS = OR > 2 THEN 2 TEXT LINE AVAILBLE (LEFT,RIGHT)
IF PANEL HEIGHT IS = OR > 3 THEN 3 TEXT LINE AVAILBLE (LEFT,RIGHT)
IF PANEL HEIGHT IS = OR > 4 THEN 4 TEXT LINE AVAILBLE (LEFT,RIGHT)
TEXT INPUT SELECTIONS: FOR 3 WAY SPLIT PANELS
IF PANEL HEIGHT IS = 1 THEN 1 TEXT LINE AVAILBLE (LEFT,CENTER,RIGHT)
IF PANEL HEIGHT IS = OR > 2 THEN 2 TEXT LINE AVAILBLE (LEFT,CENTER,RIGHT)
IF PANEL HEIGHT IS = OR > 3 THEN 3 TEXT LINE AVAILBLE (LEFT,CENTER,RIGHT)
IF PANEL HEIGHT IS = OR > 4 THEN 4 TEXT LINE AVAILBLE (LEFT,CENTER,RIGHT)
Actual height of 1 panel is 1.75" for each panel >1 just multiply 1.75 by that number.
That may not matter cause I have blocks that are set up to be inserted for each of these heights. These Blocks have Attributes to them for the text. So each user input in the slot would have to be applied to the attribute in the block..unless there is another way.
This might be too much in now but I will be happy to repeat my self later.
I guess right now we need to get the GUI in place.
Thanks for the Help and Sorry for the CAPs it wrote it in ACAD first.
