Author Topic: Howconvert a metric drawing to inches.  (Read 20157 times)
sailfl
« on: May 03, 2010, 05:15:37 PM »
I have a drawing that was drawn in metric I need to conver it to inches.
Please tell me how to do that.
JCTER
Re: Howconvert a metric drawing to inches.
« Reply #1 on: May 03, 2010, 05:19:36 PM »
Short answer:  Scale all by 25.4 or change your dimension scale to reflect inch measurements of a metric model, by scaling primary units by 25.4 or adding alternate units with a 25.4 scale.  Whichever fits the situation better.
sailfl
« Reply #2 on: May 03, 2010, 05:24:24 PM »
James,
I understand what you told me but my problem is that I don't use AC 2006 that much and I usually don't have to change drawings.  But I need to be able to do this more often, so I need some directions.
JCTER
« Reply #3 on: May 03, 2010, 05:28:15 PM »
James,
Select all objects:
SCALE
<pick base point of reference to scale objects about>
25.4 (scale factor)
Done.
« Reply #4 on: May 03, 2010, 05:43:15 PM »
*blink*
To go from metric (mm) to imperial (inches) wouldn't you scale by the inverse of 25.4, or 0.03937007874015748?
JCTER
« Reply #5 on: May 03, 2010, 05:44:17 PM »
*blink*
*facepalm*
Yes.  I was all flip flopped on my direction of scaling, there.
Or as I do it, scale by 10/254
« Reply #6 on: May 03, 2010, 05:49:36 PM »
Thanks. I read and then re-read the original question about half a dozen times because I thought I must be misinterpreting it to want to use the inverse.
sailfl
« Reply #7 on: May 03, 2010, 05:54:36 PM »
I have decided that there must be some thing else set because I am not getting what I want.  Because I can not share the file as is but I can delete some things and share a small part, I have another problem I need help with.
I can not look at the complete file.  I move toward the bottom of the file and I can not continue.
How do I see the comlete drawing?
Once I can look at the complete drawing, I will modify and post a copy of the drawing with a part.
JCTER
« Reply #8 on: May 03, 2010, 06:02:31 PM »
when you come to the limit of what you can see, hit "regen" and then continue panning around.
sailfl
« Reply #9 on: May 03, 2010, 06:16:50 PM »
Thanks for the Regen.  That works great.
Here is the drawing with a few items left.
Thanks for you help.
JCTER
« Reply #10 on: May 03, 2010, 06:24:50 PM »
If you need it in INCHES then:
SCALE entire drawing by 10/254
Turn off SNAP (F9)
Using the dialog reached via the UNITS command, change your units from decimal to fractional, with a precision more suiting to your needs, like 1/32 or 1/16 or whatever.
The dimensions will be huge, but you that may not be a problem, depending on your purpose.
Are you just trying to take measurements from this drawing?  Are you trying to use the geometry for CNC programming, or what?
sailfl
« Reply #11 on: May 03, 2010, 06:37:04 PM »
James,
I need the drawing in a 1:1 format in inches so I can cut it on my CNC machine.
Nils
Krushert
  • FREE BEER Tomorrow!!
« Reply #12 on: May 05, 2010, 08:00:05 AM »
*blink*
*facepalm*
Slick!
Got to try to remember that one if and when I ever get a metric drawing.
JCTER
« Reply #13 on: May 05, 2010, 08:22:22 AM »
*blink*
*facepalm*
Slick!
Yea, I only learned that a few months ago :P  I was always whipping out the calculator and dividing 1/25.4 (since you can't do a decimal in a fraction in Autocad) and an engineer saw me doing that one day and gave me that tip.  Brilliant!  That works in a -lot- of situations, actually, I've found.
« Reply #14 on: May 05, 2010, 08:35:16 AM »
For the uninitiated -- you can supply appropriate lisp statements to most command prompts -- for example, when prompted for scale you can simply enter (/ 1 25.4).
« Last Edit: May 05, 2010, 09:06:23 AM by MP »
