Author Topic: Howconvert a metric drawing to inches.  (Read 20144 times)
jonesy
  • SuperMod
Re: Howconvert a metric drawing to inches.
« Reply #15 on: May 05, 2010, 08:46:42 AM »
*blink*
To go from metric (mm) to imperial (inches) wouldn't you scale by the inverse of 25.4, or 0.03937007874015748?
*facepalm*
Yes.  I was all flip flopped on my direction of scaling, there.
Or as I do it, scale by 10/254
Slick!
Got to try to remember that one if and when I ever get a metric drawing.
Yea, I only learned that a few months ago :P  I was always whipping out the calculator and dividing 1/25.4 (since you can't do a decimal in a fraction in Autocad) and an engineer saw me doing that one day and gave me that tip.  Brilliant!  That works in a -lot- of situations, actually, I've found.
I've been working like that for many years, especially when trying to work out viewport scales when we're doing civils drawings as they work in meters
Big G
« Reply #16 on: July 02, 2010, 01:00:59 AM »
Ive had a few before and just changed the INSUNITS (UNITS) var to Inches (if working on a metric drg or vice versa) thus leaving the original drawing intact.......
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
Bryco
« Reply #17 on: July 02, 2010, 06:54:37 AM »
I find it easier to copy all w/ a base point and paste it in a new inches drawing at 0,0,0, then scale all. If you dont you should change the measurement, insunits and the other 2 insunit setvars to reflect inches, otherwise inserted blocks go crazy and hatch is wrong. Also you need the new dim styles
mondes
« Reply #18 on: January 04, 2011, 04:39:59 PM »
be much better to convert all the inches dwgs to metric!
Not helpful, I know.  Sorry
