Author Topic: How to modify drawing with TrueView ?  (Read 19891 times)
Andrea
« on: May 01, 2010, 03:13:02 PM »
Hi all.
All know about TrueView is a FREE viewer made by autoDESK.
This week I've learn this:
Using TrueView as an EDITOR is possible !
How to ?
-Open notePad
-write come autoCAD command such as "_GRIPS"
-select all and copy to clipboard.
than..
-Open a session of TrueView
-Paste this command in command line
there it is..
you can now select entity and copy, paste rotate etc..
How come ?
I think autocad forgot to put some reactor on copyclip.  ;-P
But !
I didn't test all commands, but it seem that "SAVE" "QSAVE" and "SAVEAS" command not working..
However, they forgot to remove "_-WBLOCK" command allowing user to save as all AutoCAD format.
 :pissed:
Keep smile...
Bob Garner
Re: How to modify drawing with TrueView ?
« Reply #1 on: May 02, 2010, 11:31:58 AM »
Finally, a way we can let our bosses try out their own little versions of autocad with trueview.  This will keep them busy for days.
But this is an incredible find, Andrea!
This isn't going to turn in to some kind of legal fiasco is it?  When will this "feature" disapear from trueview?  Certainly by the next release.  Bets are currently being taken.
Andrea
« Reply #2 on: May 03, 2010, 10:14:36 AM »
nope...it still the same thing eaven on last release..(at the moment)
 :evil:
Keep smile...
« Reply #3 on: May 03, 2010, 10:27:04 AM »
I personally think it's crazy to exploit an oversight, I mean it's only a matter of time before they fix it, so the benefits are short term and at best uncertain -- notwithstanding the ethics. Rhetorical musing ... I wonder how warm the OP would be to someone finding an oversight in the 0dcl run-times that people could exploit so they could distribute and run 0dcl based apps without requiring any licensing. Hmmm.
JCTER
« Reply #4 on: May 03, 2010, 10:29:31 AM »
It looked to me that the OP was disappointed in this dangerous oversight in the software, not overjoyed...
« Reply #5 on: May 03, 2010, 10:52:14 AM »
I don't share your interpretation.
Andrea
« Reply #6 on: May 03, 2010, 12:32:44 PM »
the fact is...
I just want to advise users that if someone use the viewer....
he can return the drawing modified..
be advised.
Keep smile...
« Reply #7 on: May 03, 2010, 12:52:32 PM »
Well forgive my misunderstanding and thanks for the warning. As not to confuse I'll leave the original post intact.
New Shooz
« Reply #8 on: May 04, 2010, 08:38:31 AM »
I've tried all I can. but I have found no way of saving / wblocking a file once I have made changes to it, using TrueView.  I should add, that I have been using the 2009 version.
However, it is possible to create non-CAD file formats from the changes i.e. pdf / dwf etc and paper copies.
This in itself, is dangerous.
This kind of information will not be getting shared out amongst my office, as they are all mostly renegeade CAD'ders anyway; a little more information in their armoury would be dangerous imo
Andrea
« Reply #9 on: May 04, 2010, 09:58:40 AM »
Well,...I think the other way...
More we have information about "BUGS" better it will be for CAD manager.
this information must be shared because it is not a cheat or a crack....but a big mistake from AutoDESK.
than, If I didn't share this information..someone else will do.
Also, I've tried "._-wblock" eaven with TrueView 2010...and still working.
for Cad Manager this information is important to know.
Keep smile...
« Reply #10 on: May 04, 2010, 10:06:07 AM »
These are NOT bugs Andrea.
You're kidding yourself if you really believe that.
Andrea
« Reply #11 on: May 04, 2010, 10:12:36 AM »
Oooh.. !  sorry Kerry,..I tought that was a viewer.   :evil:
Keep smile...
JCTER
« Reply #12 on: May 04, 2010, 10:13:25 AM »
Wow, this thread got dramatic.
« Reply #13 on: May 04, 2010, 10:16:55 AM »
If you are so concerned about it, have you advised AutoDesk ??
and I'd be intersested in your explaination of HOW 'you' discovered this functionality.
Andrea
« Reply #14 on: May 04, 2010, 10:34:23 AM »
Someone show me this information and was already on the net.
here
Yes, AutoDESK as been advised and already know about this "Bug".
Keep smile...
