Author Topic: You can change this routine?  (Read 866 times)
yiyorebel
« on: April 22, 2010, 04:25:05 PM »
Hi, well the idea is to optimize this routine, the dwg explain how it works and also how it can work to optimize time .... thank you very much.
regards
HasanCAD
Re: You can change this routine?
« Reply #1 on: April 23, 2010, 05:28:19 AM »
first of all its good idea, and need some organization
Add underline and dot next to the command
(command "_.donut" "0.0" "2.5" pd1 "")instead of
(command "donut" "0.0" "2.5" pd1 "")
What about the distance between bars?
What about the gab (cover) distance between the bars and wall edge?
yiyorebel
« Reply #2 on: April 23, 2010, 10:36:20 AM »
Hi, thanks for your interest in this routine, the distance between bars is 20 cm. and the distance between the bar and the edge of the wall is 2.5 cm.
I hope it will because I believe this modification will serve well and save you much time.
Thank you very much:wink:
