Author Topic: Perpendicular OSNAP  (Read 2898 times)
Andrea
Perpendicular OSNAP
« on: April 22, 2010, 11:51:49 AM »
Hi all...
it's about a long time heun ?  ;-)
sorry, I'm very busy..
Well, I would like to know if anyone have a clue for this.
(while (eq (car (setq input (grread t 4 4))) 5)
(setq vs (/ (getvar "Viewsize") 60.0))
(setq snappoint (osnap (cadr input) "_per"))
  (redraw)
(if snappoint
  (grdraw (polar snappoint 3.92699 vs) (polar snappoint 0.785398 vs) 2 0)
  (grdraw (polar snappoint -0.785398 vs) (polar snappoint 2.35619 vs) 2 0)
any help will be appreciated.
Thanks.
Keep smile...
Re: Perpendicular OSNAP
« Reply #1 on: April 22, 2010, 11:53:34 AM »
Andrea
« Reply #2 on: April 22, 2010, 01:29:42 PM »
thanks Lee,
I've take a look and tested the code of Elpanov
.....but it seem to not working on 2011.
however, I've found some interesting snippet who maybe can help me for this issue....
thanks.
Keep smile...
« Reply #3 on: April 22, 2010, 05:44:08 PM »
Not a problem - that code helped me incorporate OSnap into my programs that run on GrRead (its not perfect, but it is a pretty good substitute) - GrRead with OSnap is on my wishlist  :-)
alanjt
  • Standby for witty remark...
« Reply #4 on: April 22, 2010, 07:45:12 PM »
It would definitely make them usable in a lot of situations.
Dropbox
Andrea
« Reply #5 on: April 23, 2010, 11:21:46 AM »
I,ve create my own grread SNAPS.....the only problem is the perpedicular one..
i'll try to found a solution..
When it'll be done....I'll post here..
thanks.
Keep smile...
VovKa
  • Ukraine
« Reply #6 on: April 23, 2010, 01:24:13 PM »
the solution is "LASTPOINT"
  (redraw)
  (if snappoint
    (progn (grdraw (polar snappoint 3.92699 vs) (polar snappoint 0.785398 vs) 2 0)
  (entmake
    (list (cons 0 "LINE") (cons 10 (getvar "LASTPOINT")) (cons 11 snappoint))
  (setvar "LASTPOINT" snappoint)
« Last Edit: April 23, 2010, 02:44:38 PM by VovKa »
Andrea
« Reply #7 on: April 27, 2010, 11:49:45 AM »
  (redraw)
  (if snappoint
  (entmake
Thanks vovka..
That.s what I've done..
but with some additional condition.
like if there is no first pick point..
Thanks again.
Keep smile...
