Author Topic: Delete duplicate blocks from drawing  (Read 3054 times)
ELOQUINTET
« on: April 21, 2010, 12:40:17 PM »
Hey,
I have looked online but have not found what I'm looking for so I came here to see if anyone has written something like this. Basically I have a bunch of blocks in a drawing and I need to delete all of the duplicates leaving me only with blocks that have unique names. Can someone help me with this? Thanks
David Bethel
Re: Delete duplicate blocks from drawing
« Reply #1 on: April 21, 2010, 12:55:08 PM »
I'd try something like this:
(defun c:eblock (/ i ss en bn bl)
  (and (setq i -1
            ss (ssget "X" '((0 . "INSERT"))))
       (while (setq en (ssname ss (setq i (1+ i))))
              (setq bn (cdr (assoc 2 (entget en))))
              (if (not (member bn bl))
                  (setq bl (cons bn bl))
                  (entdel en))))
  (prin1))
Totally untested.  -David
R12 Dos - A2K
« Reply #2 on: April 21, 2010, 01:40:48 PM »
I would think you may want to:
Select Inserts to keep
Build a list of block names
ssget all inserts with those name
remove the keepers from the selection set
then entdel the remaining
