Author Topic: sort items into a selection set.  (Read 22388 times)
SMadsen
« Reply #30 on: November 27, 2003, 09:14:06 AM »
CAB, great that you could learn from it. Please grab whatever else you can step through and learn from. Mark posted a nice little mapcar/lambda routine in your thread in Teach Me. That should be worth stepping through to pick up some list logic.
By the way, what is "analized"? It sounds kinky but painfull :)
« Reply #31 on: November 27, 2003, 10:50:04 AM »
Ooooops,
Spell checker doesn't work if you don't use it.
Mark I thought you were going to add one. :)
That vla- stuff is still kicking my but I'll take a look at Mark's routine.
On second look he only used vl-remove, I should be able to handle that :)
  • Custom Title
« Reply #32 on: December 01, 2003, 07:21:23 AM »
Quote from: CAB
Way to much coding! Take a look at this though, I use it all the time, it's a great little app. http://www.iespell.com/
Quote from: CAB
The vl- functions are nothing fancy, just functions. The fun starts with the vlax- stuff. :D
« Reply #33 on: December 01, 2003, 07:46:35 AM »
Thanks Mark,
I  downloaded the spell check.
Yes I meant the vlax stuff.. :)
daron
« Reply #34 on: December 03, 2003, 12:22:37 AM »
Quote from: CAB
Isn't Se7en the "Spell Checker"?
