Doslib is not the only arx i want to load .Is it possible to add
Idwgtab
Periscope
Quikpik
to this code.?
(defun ISX64 (/ proc_arch)
(and
(setq proc_arch (getenv "PROCESSOR_ARCHITECTURE"))
(< 1 (strlen proc_arch))
(eq "64" (substr proc_arch (1- (strlen proc_arch))))
;; determine whether appropriate version of DOSLib is already loaded.
;; if not, try to load it.
(setvar "cmdecho" 0)
(setq CADver (substr (getvar "acadver") 1 2)) ;; i.e., "17", "18", etc.
(setq arxlist (arx))
(if (isX64)
(setq DOSLibname (strcat "doslib" CADver "x64.arx"))
(setq DOSLibname (strcat "doslib" CADver ".arx"))
(foreach a arxlist (if (equal a DOSLibname) (setq loadedAtStartup T) ))
(if (not loadedAtStartup)
(vl-cmdf "._arx" "_load" (findfile DOSLibname))
;; verify that load was successful.
;; if not, quit.
(foreach a arxlist (if (equal a DOSLibname) (setq loadedAtRuntime T) ))
(if (not loadedAtRuntime)
(prompt "Sorry - DOSLib is not loaded and cannot be found in the
AutoCAD search path.")
(vlr-beep-reaction)
(quit)
(setvar "cmdecho" 1)
