Cab,
I have the 3 point info. I need to entmake the ARC based on those values only.
So far:
The chord from start to end, therfore the mid point of the chord.
In this case the second point is the mid point of the arc, but thats not always the case
So I guess I could form a a right triangle from an end_point, mid_chord_pt, and mid_arc_pt
I think there is a formula to determine the center based on chord length and chord height ( Somewhere floating around me feeble mind) -David
