Author Topic: -={ Challenge }=- Group By Assoc  (Read 8894 times)
Re: -={ Challenge }=- Group By Assoc
« Reply #15 on: April 04, 2010, 01:11:42 PM »
« Last Edit: April 04, 2010, 11:05:12 PM by Trauma »
« Reply #16 on: April 04, 2010, 01:19:17 PM »
A test with a longer list reveals more...  :evil:
List Length: 80
Elapsed milliseconds / relative speed for 16384 iteration(s):
    (GILE_GROUPBYASSOC LST)......1310 / 8.00 <fastest>
    (GBA-EE LST).................4056 / 2.58
    (MAC_GROUPBYASSOC LST)......10484 / 1.00 <slowest>
My laptop's not fast enough to process lists much longer than that  :|
« Reply #17 on: April 04, 2010, 01:33:39 PM »
Another  :-)
(defun Mac_GroupByAssoc4 ( lst / item rtn out)
  (setq item (caar lst) rtn (cdar lst))
  (while (setq lst (cdr lst))
    (while (and lst (setq a (assoc item lst)))
      (setq rtn (append rtn (cdr a)) lst (vl-remove a lst)))
    (setq out (cons (cons item rtn) out) item (caar lst) rtn (cdar lst)))
  (reverse out))
« Reply #18 on: April 04, 2010, 01:34:55 PM »
List Length: 5
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (MAC_GROUPBYASSOC4 LST).....1482 / 1.41 <fastest>
    (MAC_GROUPBYASSOC LST)......1528 / 1.37
    (GILE_GROUPBYASSOC LST).....1576 / 1.33
    (GBA-EE LST)................2090 / 1.00 <slowest>
List Length: 80
    (MAC_GROUPBYASSOC4 LST).....1139 / 8.49 <fastest>
    (GILE_GROUPBYASSOC LST).....1170 / 8.27
    (GBA-EE LST)................3697 / 2.62
    (MAC_GROUPBYASSOC LST)......9672 / 1.00 <slowest>
 8-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: April 04, 2010, 02:20:50 PM »
Hi Lee! :)
(Mac_GroupByAssoc4 '((1 2) (1 2) (1 2))) ;=>> ((1 2 2))
(GroupByAssoc '((1 2) (1 2) (1 2)))      ;=>> ((1 2 2))
(gba-ee '((1 2) (1 2) (1 2)))           ;=>> ((1 2 2 2))
« Last Edit: April 04, 2010, 02:25:53 PM by ElpanovEvgeniy »
« Reply #20 on: April 04, 2010, 02:34:24 PM »
I wondered who'd be the first to spot that...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #21 on: April 04, 2010, 02:40:34 PM »
Now I do not know, I must make a new version?  :kewl:
« Reply #22 on: April 04, 2010, 02:50:42 PM »
No, I think your version is the correct way to deal with that situation - I just wish there was a function like vl-remove that would only remove the first occurence of an item.  :-(
« Reply #23 on: April 04, 2010, 03:12:48 PM »
I thought I'd try to write my own, but I cannot seem to get this to work  :-(
(defun vl-remove-1st (x l / foo)
    (defun foo (y)
      (if (equal x y)
        (defun foo (y) nil)))
    (vl-remove-if (function foo) l))
« Reply #24 on: April 04, 2010, 03:22:06 PM »
Don't have time to optimize but ...
(defun remove-first-if ( foo lst / bar )
    (defun bar (x) (if (foo x) (defun foo (x) nil)))
    (vl-remove-if 'bar lst)
(remove-first-if
    (lambda (x) (eq 2 x))
   '(0 1 2 2 3 4 5 6 7 8)
=> (0 1 2 3 4 5 6 7 8)
« Reply #25 on: April 04, 2010, 03:37:32 PM »
Thanks Michael - appreciated.
I couldn't work out why my solution failed though  :-(
With my code
    (defun foo (y)
      (if (equal x y)
For say,
(vl-remove-1st 1 '(1 2 3 1 2 3))
I would have thought the first item is fed to foo, the IF statement evaluates and redefines foo (hence returning T, and so the first item is removed), and subsequent evaluation of foo would return nil (hence no more items are removed).
What is wrong in my reasoning?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #26 on: April 04, 2010, 03:54:09 PM »
my version remove first
(defun r1 (x l)
  ((not l)nil)
  ((= x (car l))(cdr l))
  ((cons (car l)(r1 x(cdr l))))))
« Reply #27 on: April 04, 2010, 03:57:33 PM »
As usual - nice idea Evgeniy!  :lol:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #28 on: April 04, 2010, 04:16:30 PM »
(defun r2 (x l / ll)
 ;;iteration
 (while (and l (/= (car l) x))
  (setq ll (cons (car l) ll)
        l  (cdr l)
  ) ;_  setq
 ) ;_  while
 (if l
  (append (reverse ll) (cdr l))
  (reverse ll)
 ) ;_  if
gile
  • Marseille, France
« Reply #29 on: April 04, 2010, 04:43:28 PM »
A new version which doesn't remove duplicated items
(defun GroupByAssoc (lst / f1 f2)
  (defun f1 (a l / b)
    (if (setq b (assoc (car a) l))
      (f1 (append a (cdr b)) (removefirst b l))
      (cons a (f2 l))
  (defun f2 (l)
    (if (cdr l)
      (f1 (car l) (cdr l))
      l
  (f1 (car lst) (cdr lst))
(defun removefirst (item lst)
  (if (or (equal item (car lst)) (null lst))
    (cdr lst)
    (cons (car lst) (removefirst item (cdr lst)))
« Last Edit: April 04, 2010, 04:56:37 PM by gile »
