Author Topic: -={ Challenge }=- Group By Assoc  (Read 9074 times)
« on: April 03, 2010, 08:38:46 AM »
The Challenge:
To emulate the behaviour of the Express Tools' acet-list-group-by-assoc function, (however the list should be in the correct order, unlike that function...). The function needn't accomodate for dotted pairs.
Example:
(setq lst '((1 123 234) (2 234 345) (3 345 456) (2 456 567) (3 567 678)))
==> ((1 123 234) (2 234 345) (3 345 456) (2 456 567) (3 567 678))
(reverse (acet-list-group-by-assoc lst))
==> ((1 123 234) (2 234 345 456 567) (3 345 456 567 678))
I'll kick us off, as an example:
(defun _GroupByAssoc ( lst / rtn a )
  (setq rtn (list (car lst)))
  (while (setq lst (cdr lst))
    (setq rtn
      (if (setq a (assoc (caar lst) rtn))
        (subst (cons (car a) (append (cdr a) (cdar lst))) a rtn)
        (cons (car lst) rtn))))
  (reverse rtn))
Enjoy,
Lee
Re: -={ Challenge }=- Group By Assoc
« Reply #1 on: April 03, 2010, 05:30:10 PM »
Here is my c++ entry.
int main ( )
   sort a three dimensional array by first colum using the bubble sort.
   the array:
    (1 123 234)
    (2 234 345)
    (3 345 456)
    (2 456 567)
    (3 567 678)
        int rows = 5,
            cols = 3;
        int r,
            c = 0;
        int tmp[1][3];
            // temp array to hold value while switch is made.
        int nums[5][3] = {
                {1, 123, 234},
                {2, 234, 345},
                {3, 345, 456},
                {2, 456, 567},
                {3, 567, 678}};
        cout << "\nOrig array is:\n";
        for(r=0; r<rows; r++)
                // print the array
                for(c=0; c<cols; ++c) cout << '\t' << nums[r][c];
                // print each entry
                cout << endl;
                // add a line break
        cout << endl;
        for(r=1; r<rows; r++)
                // if array entry is bigger then the previous
                // entry, swap them
                if(nums[r][0] < nums[r-1][0])
                        for(c=0; c<cols; c++)
                           tmp[0][c] = nums[r-1][c];
                           nums[r-1][c] = nums[r][c];
                           nums[r][c] = tmp[0][c];
        cout << "\nSorted array is:\n";
                // print the array
                // print each entry
                cout << endl;
                // add a line break
        return 0;
Orig array is:
        1       123     234
        2       234     345
        3       345     456
        2       456     567
        3       567     678
Sorted array is:
        1       123     234
        2       234     345
        2       456     567
        3       345     456
        3       567     678
« Reply #2 on: April 04, 2010, 07:05:35 AM »
Thanks John  :-)
It seems the challenge isn't as interesting as the other one, but I'm having fun anyway  :-)
Here's an attempt at 'Bicursion'  :-)
(defun _GroupByAssoc2 ( lst / g f )
  (defun g ( l )
    (if l
      (f (caar l) l)))
  (defun f ( x l )
    (cons
      (cons x (apply (function append)
                     (mapcar (function cdr)
                             (vl-remove-if-not
                               (function
                                 (lambda (pair) (= x (car pair)))) l))))
      (g (vl-remove-if (function (lambda (pair) (= x (car pair)))) l))))
  (g lst))
qjchen
  • Best wishes to all
« Reply #3 on: April 04, 2010, 08:21:13 AM »
Hi, Lee mac:)
When I finish the code, I feel it is similar to your first code.
(defun c:test ()
  (setq lst '((9 1111)
(3 345 456)
(2 456 567)
(4 678 789 90)
(3 567 678)
(1 111)
  (chenGroupassoc lst)
(defun chenGroupassoc (lst / res a b item)
  (setq res (list (car lst)))
    (setq a (car lst) b (car a))
    (if (not (setq item (assoc b res)))
      (setq res (append res (list a)))
        (setq res (subst (append item (cdr a)) item res))))
« Last Edit: April 04, 2010, 09:04:26 AM by yuanqiu »
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
gile
  • Marseille, France
« Reply #4 on: April 04, 2010, 09:40:48 AM »
Hi
A cross recursive example
(defun GroupByAssoc (lst / f1 f2)
  (defun f1 (a l / b)
    (if (setq b (assoc (car a) l))
      (f1 (append a (cdr b)) (vl-remove b l))
      (cons a (f2 l))
  (defun f2 (l)
    (if (cdr l)
      (f1 (car l) (cdr l))
      l
  (f1 (car lst) (cdr lst))
« Reply #5 on: April 04, 2010, 09:53:25 AM »
Very nice Gile!  I like it  :-)
« Reply #6 on: April 04, 2010, 10:34:23 AM »
Another to mess with the mind  :lol:
(defun _GroupByAssoc3 ( lst / g f )
  (defun g ( a b )
    (if a
      (if (assoc (caar a) b)
        (g (cdr a) b)
        (g (cdr a)
           (cons
             (cons (caar a)
                (f (caar a) a)) b))) b))
  (defun f ( x l )
    (if l
      (if (= x (caar l))
        (append (cdar l) (f x (cdr l)))
        (f x (cdr l)))))
  (reverse (g lst nil)))
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #7 on: April 04, 2010, 10:41:12 AM »
my version:
(defun gba-ee (l / a)
 (setq l (vl-sort l (function (lambda (a b) (>= (car a) (car b)))))
       a nil
 (while l
  (setq a (cons (car l) a)
        l (cdr l)
  (while (and l (= (caar l) (caar a)))
   (setq a (cons (cons (caar l) (append (cdar l) (cdar a))) (cdr a))
         l (cdr l)
 a
« Reply #8 on: April 04, 2010, 11:06:09 AM »
Nice idea Evgeniy  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: April 04, 2010, 11:09:17 AM »
I hope this idea will give odds to speed ... :)
« Reply #10 on: April 04, 2010, 11:11:02 AM »
But would Sorting reduce speed for longer lists...  :angel:
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #11 on: April 04, 2010, 11:12:51 AM »
Yes, sorting is very fast!
Particularly noticeable is in large lists...
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: April 04, 2010, 11:20:56 AM »
What's the difference between 'cross recursive' and 'Bicursion'... just so I know I'm properly dressed   :laugh:
« Reply #13 on: April 04, 2010, 11:23:10 AM »
What's the difference between 'cross recursive' and 'Bicursion'...  :laugh:
Bicursion is a term I picked up from this thread  :-)
« Reply #14 on: April 04, 2010, 01:08:28 PM »
Quick speed test:
Intel Core2Duo @ 2.1GHz
3GB RAM
Elapsed milliseconds / relative speed for 16384 iteration(s):
    (MAC_GROUPBYASSOC LST)......1201 / 5.61 <fastest>
    (GILE_GROUPBYASSOC LST).....1264 / 5.33
    (GBA-EE LST)................1872 / 3.60
    (MAC_GROUPBYASSOC3 LST).....1903 / 3.54
    (MAC_GROUPBYASSOC2 LST).....6740 / 1.00 <slowest>
