Author Topic: {Challenge} connect each two points whose distance is shorter than given value  (Read 101132 times)
gile
  • Marseille, France
I know this is a (very) old thread, but after trying the k-d tree route with C#, I've been playing with the divide and conquer one (using xy grid as shown by qjchen) and F#.
The code is quite concise and performances not so bad 8-).
Code - F#: [Select]
  1. module ConnectPointChallenge
  2.
  3. open Autodesk.AutoCAD.DatabaseServices
  4. open Autodesk.AutoCAD.EditorInput
  5. open Autodesk.AutoCAD.Geometry
  6. open Autodesk.AutoCAD.Runtime
  7.
  8. type AcAp = Autodesk.AutoCAD.ApplicationServices.Application
  9.
  10. let connectAll (pts: Point3d[]) dist =
  11.     let getExtents pts =
  12.         Seq.fold(fun (s: Extents3d) p -> s.AddPoint(p); s) (new Extents3d()) pts
  13.     let ext = getExtents pts
  14.     let xMax, yMax = ext.MaxPoint.X, ext.MaxPoint.Y
  15.     let xMin, yMin = ext.MinPoint.X, ext.MinPoint.Y
  16.     let col, row = int ((xMax - xMin) / dist) + 2, int ((yMax - yMin) / dist) + 3
  17.     let table = Array2D.create col row []
  18.     pts |> Seq.iter(fun p ->
  19.                 let i, j = int ((p.X - xMin) / dist), int ((p.Y - yMin) / dist) + 1
  20.                 table.[i, j] <- p :: table.[i, j])
  21.     let dist = dist * dist
  22.
  23.     let getConnexions i j =
  24.         let sqrDist2d (p1: Point3d) (p2: Point3d) =
  25.             (p1.X - p2.X) * (p1.X - p2.X) + (p1.Y - p2.Y) * (p1.Y - p2.Y)
  26.         let connect pt pts acc =
  27.             List.fold(fun s p -> if sqrDist2d pt p <= dist then (pt, p) :: s else s) acc pts
  28.         let connectInside pts =
  29.             let rec loop acc = function
  30.                 | [] -> acc
  31.                 | h :: t -> loop (connect h t acc) t
  32.             loop [] pts
  33.         let connectOutside pts acc =
  34.             List.fold(fun s p -> connect p pts s) acc table.[i,j]
  35.         table.[i,j]
  36.         |> connectInside
  37.         |> connectOutside table.[i + 1, j - 1]
  38.         |> connectOutside table.[i + 1, j]
  39.         |> connectOutside table.[i + 1, j + 1]
  40.         |> connectOutside table.[i, j + 1]
  41.
  42.     [| for i in 0 .. col - 2 do
  43.         for j in 1 .. row - 2 do yield! getConnexions i j |]
  44.
  45. [<CommandMethod("ConnectFs")>]
  46. let connectFs () =
  47.     let sw = new System.Diagnostics.Stopwatch()
  48.     let doc = AcAp.DocumentManager.MdiActiveDocument
  49.     let db = doc.Database
  50.     let ed = doc.Editor
  51.     sw.Start()
  52.     use ms = SymbolUtilityServices.GetBlockModelSpaceId(db).Open(OpenMode.ForWrite)
  53.              :?> BlockTableRecord
  54.     let rxc = RXClass.GetClass(typeof<DBPoint>)
  55.     let pts = [| for id in ms -> id |]
  56.               |> Array.filter(fun id -> id.ObjectClass = rxc)
  57.               |> Array.map(fun id ->
  58.                     use pt = id.Open(OpenMode.ForRead) :?> DBPoint
  59.                     pt.Position)
  60.     let t0 = sw.ElapsedMilliseconds
  61.     let pairs = connectAll pts 70.0
  62.     let t1 = sw.ElapsedMilliseconds
  63.     pairs
  64.     |> Array.iter (fun (p1, p2) ->
  65.         use line = new Line(p1, p2)
  66.         ms.AppendEntity(line) |> ignore)
  67.     sw.Stop()
  68.     let t2 = sw.ElapsedMilliseconds
  69.     ed.WriteMessage(
  70.         "\nGet points:{0,9}\nConnect points:{1,5}\nDraw lines:{2,9}\nTotal:{3,14}",
  71.         t0, t1 - t0, t2 - t1, t2);
10K points => 12,718 lines
Elapsed milliseconds:
Get points:       35
Connect points:   21
Draw lines:       56
Total:           112
100k points => 128,026 lines
Get points:      254
Connect points:  272
Draw lines:      633
Total:          1159
1M points => 1,280,741 lines
Get points:     2453
Connect points: 2792
Draw lines:    11748
Total:         16993
« Last Edit: June 22, 2013, 03:50:56 PM by gile »
qjchen
  • Best wishes to all
Thank you very much, gile.
It is really quite concise.
I am regret that recently I am too busy to write programs.
I hope I could learn your code carefully for study.
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
