Author Topic: {Challenge} connect each two points whose distance is shorter than given value  (Read 101421 times)
qjchen
  • Best wishes to all
Attachment is a dwg contains 10000 random points.
Then the challenge is to connect each two points whose distance is shorter than given value, in this dwg the value is 70.
My first code (as follows) is very very slow for 10000 points, when for few points, it can solve. And I think I can improve it more quickly.
I hope you can give more effective way.
;;stdlib
(defun std-sslist (ss / n lst)
  (if (eq 'pickset (type ss))
    (repeat (setq n (fix (sslength ss))) ; fixed
      (setq lst (cons (ssname ss (setq n (1- n))) lst))
;;make layer or turn on current layer
(defun mylayer (str)
  (if (tblsearch "LAYER" str)
    (command "._-Layer" "_set" str "")
    (command "._-Layer" "_Make" str "")
;;entmake line
(defun entmakeline (pt1 pt2 layer)
  (entmake (list (cons 0 "LINE") ;***
(cons 6 "BYLAYER") (cons 8 layer) (cons 10 pt1) ;***
(cons 11 pt2) ;***
(cons 39 0.0) (cons 62 256) (cons 210 (list 0.0 0.0 1.0))
;;get the point coordinate
(defun mygetpoint (lst / plst)
  (foreach x lst
    (setq plst (append
plst
(list (cdr (assoc 10 (entget x))))
  plst
;;Main
(defun c:gap ( / c i j len len1 limdis pj plst x)
  (mylayer "temp")
  (setq limdis 70)
  (setq c (ssget '((0 . "POINT"))))
  (setq c (std-sslist c))
  (setq plst (mygetpoint c))
  (setq i 0
len (length plst)
  (foreach x plst
    (princ "\n               i = ") (princ i);Erase_DV
    (setq j (1+ i)
 len1 (- len j)
    (repeat len1
      (setq pj (nth j plst))
      (if (< (distance x pj) limdis)
(entmakeline x pj "temp")
      (setq j (1+ j))
    (setq i (1+ i))
« Last Edit: April 02, 2010, 09:01:51 PM by yuanqiu »
http://qjchen.mjtd.com
My blog http://chenqj.blogspot.com (Chinese, can be translate into English)
zomg it's full of starz!!
Well ... here's mine to start it off  :-)
(defun c:test (/ d e n out pt ss)
  (and
    (setq n -1)
    (setq d 70.)
    (setq ss (ssget '((0 . "point"))))
    (while (setq e (ssname ss (setq n (1+ n))))
      (setq out (cons (cdr (assoc 10 (entget e))) out))
    (setq out (vl-sort out (function (lambda (x1 x2) (< (car x1) (car x2))))))
    (while (setq pt (car out))
      (mapcar (function
(lambda (x) (entmakex (list '(0 . "LINE") (cons 10 pt) (cons 11 x))))
      (vl-remove-if
(function (lambda (x) (>= (distance pt x) d)))
(setq out (cdr out))
« Last Edit: April 02, 2010, 01:34:18 PM by ronjonp »
Not sure how quick this'll be:
(defun PointGap (gap / GetPoints Pts tmp x y)
  (defun GetPoints (ss / e i l)
    (setq i -1)
    (if ss
      (while (setq e (ssname ss (setq i (1+ i))))
        (setq l (cons (cdr (assoc 10 (entget e))) l))))
    l)
  (if (setq Pts (GetPoints (ssget "_X" '((0 . "POINT")))))
    (while (setq x (car Pts))
      (setq tmp (cdr Pts))
      (while (setq y (car tmp))
        (if (< (distance x y) gap)
          (entmakex (list (cons 0 "LINE")
                          (cons 10 x) (cons 11 y))))
        (setq tmp (cdr tmp)))
      (setq Pts (cdr Pts))))
  (princ))
alanjt
  • Standby for witty remark...
(_connect (_GetPnts) 70.))
(_connect2 (_GetPnts) 70.))
(defun _GetPnts (/ ss i)
  (setq i -1)
  (if (setq ss (ssget "_X" '((0 . "POINT"))))
    ) ;_ while
  ) ;_ if
) ;_ defun
(defun _Line (a b) (entmakex (list '(0 . "LINE") (cons 10 b) (cons 11 a))))
(defun _connect (lst d / lst)
  (foreach x lst
    (foreach i (setq lst (vl-remove x lst))
      (and (< (distance x i) d)
           (_Line x i)
      ) ;_ and
    ) ;_ foreach
  ) ;_ foreach
) ;_ defun
(defun _connect2 (lst d / lst)
  (while (setq a (car lst))
    (foreach x (setq lst (cdr lst))
      (and (< (distance a x) d)
           (_Line a x)
      ) ;_ and
    ) ;_ foreach
  ) ;_ while
) ;_ defun
Dropbox
gile
  • Marseille, France
Here's my way, quite similar to those posted before.
(defun foo (dist / n ss ent lst pt)
  (if (setq n  -1
    (while (setq ent (ssname ss (setq n (1+ n))))
      (setq lst (cons (cdr (assoc 10 (entget ent))) lst))
  (while lst
    (setq pt  (car lst)
  lst (cdr lst)
    (foreach p lst
      (if (<= (distance pt p) dist)
(entmake (list '(0 . "LINE") (cons 10 pt) (cons 11 p)))
alanjt
Would have been smart of me to do the same.
Dropbox
pkohut
Ug, to busy to play, but can't resist   ^-^. Will post ARX code in a bit.
gile
  • Marseille, France
A C# solution
Much more faster than LISP. With the sample drawing and a 70.0 length:
LISP = about 45 seconds
C# = about 2 seconds
Maybe ARX shoulde be faster...
using System;
namespace ChallengeConnectPoints
    public class Connect
        [CommandMethod("Test")]
        public void Test()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptDistanceOptions pdo = new PromptDistanceOptions("\nConnection distance: ");
            pdo.AllowNegative = false;
            pdo.AllowZero = false;
            PromptDoubleResult pdr = ed.GetDistance(pdo);
            if (pdr.Status == PromptStatus.OK)
                ConnectPoints(pdr.Value);
        private void ConnectPoints(double d)
            Database db = doc.Database;
            Editor ed = doc.Editor;
            TypedValue[] tv = new TypedValue[1] { new TypedValue(0, "POINT") };
            PromptSelectionResult psr = ed.SelectAll(new SelectionFilter(tv));
            if (psr.Status != PromptStatus.OK)
                return;
                Point3d[] pts = Array.ConvertAll<ObjectId, Point3d>(
                    psr.Value.GetObjectIds(), x => ((DBPoint)x.GetObject(OpenMode.ForRead)).Position);
                int cnt = pts.Length;
                BlockTableRecord btr =
                    (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                for (int i = 0; i < cnt; i++)
                    for (int j = i + 1; j < cnt; j++)
                        if (pts[i].DistanceTo(pts[j]) <= d)
                            Line l = new Line(pts[i], pts[j]);
                            btr.AppendEntity(l);
                            tr.AddNewlyCreatedDBObject(l, true);
                tr.Commit();
You can try tne DLL in the ZIP file.
« Last Edit: April 02, 2010, 06:19:29 PM by gile »
pkohut
A C# solution
Nice Gile.
I'm taking a none brute force approach, initial results look promising  ;-) Have an hour or so of coding left to do.
alanjt
Man, one really pays for performance. I'm not knocking C/Arx, just taken aback at the amount of time.
Dropbox
pkohut
Your right, and this is even repurposing code I've already written. The solution though is non-trivial, but screams. Tested with a million points and it's under a second. Still coding though so back to work  :lmao:
alanjt
:lol:
Can't wait to see it!!
Dropbox
:lol:
Yes you can, really, you can.  :-)
qjchen
Thank you all :), Your algorithms are all faster than me.
In my PC, (E7500 CPU, 4G Mem)
Ronjonp 's code, about 34.812967s
Lee Mac's code, about 40.733018s
Gile's code 42.111982s
alanjt's code is about 50s
Mine first code is very slow.   :-D, (could you tell me which cause the very slow)
Not very accurate test.
And I hope to see pkohut's super code :)
I am thinking about the "Divide and conquer algorithm", but I need some time to sort the point in some manner, and not so sure about whether it can be improved, because the sort also need some times.
