Author Topic: Question about SSDel  (Read 5114 times)
alanjt
  • Standby for witty remark...
« on: April 01, 2010, 03:26:58 PM »
If I define a selection set to a variable, then copy that variable (assign it to another), and the ssdel an ename out of the variable, why does it remove it from the first variable selection set?
eg.
Command: (sslength (setq s1 (ssget)))
Select objects: Specify opposite corner: 8 found
Select objects:
8
Command: (setq s2 s1)
<Selection set: ffea>
Command: (sslength (ssdel (ssname s2 0) s2))
7
Command: (sslength s1)
7
Dropbox
Re: Question about SSDel
« Reply #1 on: April 01, 2010, 03:30:16 PM »
for performance and economy reasons selection sets are "special" (not like se7en) in that they behave more like pointers, thus when you set one selection set to another they both actually point to the same object
Jeff_M
  • C3D user & customizer
« Reply #2 on: April 01, 2010, 03:32:42 PM »
Short answer...... Because both variable are referencing the same SelectionSet - <Selection set: ffea>
Longer answer, someone should be along with one :-) Crud, Trauma happens quick!
alanjt
« Reply #3 on: April 01, 2010, 03:35:21 PM »
OK, that make sense. I guess I was thinking about it like a list. Thanks guys.
Dropbox
alanjt
« Reply #4 on: April 01, 2010, 03:38:43 PM »
I was trying to accomplish this:
(defun test (ss)
  (while (setq e (ssname ss 0))
    (cons e (test (ssdel e ss)))
  ) ;_ while
) ;_ defun
[color=red]OR[/color]
(defun test (ss / s2)
  (while (setq e (ssname (setq s2 ss) 0))
    (cons e (test (ssdel e s2)))
  ) ;_ while
) ;_ defun
But, I'll just use this:
(defun AT:SS->List (SS VLA / l)
  ((lambda (i)
     (if VLA
       (while (setq e (ssname SS (setq i (1+ i)))) (setq l (cons (vlax-ename->vla-object e) l)))
       (while (setq e (ssname SS (setq i (1+ i)))) (setq l (cons e l)))
     ) ;_ if
   ) ;_ lambda
    -1
) ;_ defun
« Last Edit: April 01, 2010, 03:43:00 PM by alanjt »
Dropbox
LE3
« Reply #5 on: April 01, 2010, 03:40:08 PM »
to play with a little with lisp again, that you have to do something in the ugly lines below:
(setq s2 (ssadd))
(setq i 0)
(repeat (sslength s1)
  (ssadd (ssname s1 i) s2)
  (setq i (1+ i)))
then you will have another selection...
« Last Edit: April 01, 2010, 04:15:47 PM by LE3 »
alanjt
« Reply #6 on: April 01, 2010, 03:42:43 PM »
(setq s2 (ssadd))
(setq i 0)
  (setq i (1+ i)))
Ahh, thanks Luis. :)
Dropbox
alanjt
« Reply #7 on: April 01, 2010, 03:48:16 PM »
or this...
  ((lambda (i)
     (if VLA
       (repeat (sslength SS)
         (setq l (cons (vlax-ename->vla-object (ssname SS (setq i (1+ i)))) l))
       ) ;_ repeat
       (repeat (sslength SS) (setq l (cons (ssname SS (setq i (1+ i))) l)))
     ) ;_ if
   ) ;_ lambda
    -1
) ;_ defun
Dropbox
« Reply #8 on: April 01, 2010, 03:48:57 PM »
I won't bother showing how to copy a selection set since LE3 anted up, so here's a different offering for one of your "alt" approaches ...
(defun _PicksetToEnames ( ss )
    (if (eq 'pickset (type ss))
        (mapcar
           '(lambda ( x ) (cadr x))
            (vl-remove-if '(lambda ( x ) (minusp (car x))) (ssnamex ss))
alanjt
« Reply #9 on: April 01, 2010, 03:58:00 PM »
        (mapcar
I used something very similar (used vl-remove-if 'listp), but wanted to replace it with something a bit faster (slow day and wanted to do a little optimizing).
Command: (benchmark '( (_picksettoenames s) (at:ss->list s nil) ))
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (AT:SS->LIST S nil)......1890 / 3.71 <fastest>
    (_PICKSETTOENAMES S).....7016 / 1 <slowest>
Using my While one.
I hope you don't think I'm trying to tell you anything. I've learned so much just from looking at your posted examples.
Dropbox
alanjt
« Reply #10 on: April 01, 2010, 04:04:05 PM »
I completely forgot about checking if the variable was valid. Thank you.
I think I'll go with this...
  (if (eq 'PICKSET (type SS))
    ((lambda (i)
         (if VLA
           (setq l (cons e l))
         ) ;_ if
       ) ;_ while
     ) ;_ lambda
      -1
  ) ;_ if
) ;_ defun
Dropbox
« Reply #11 on: April 01, 2010, 04:05:35 PM »
cool, on quick glance I wouldn't have guessed that significant a performance difference.
The minute a man thinks he knows it all he becomes a fool, subtitle: bring it on brother, it's all good, and thanks for the edumacation.
Thanks for the acknowledgment Alan, nice of you to say and it takes the edge off the smashing headache I'm sporting today.
alanjt
« Reply #12 on: April 01, 2010, 04:13:35 PM »
I was pretty surprised too.
Thanks for understanding. :)
Dropbox
« Reply #13 on: April 01, 2010, 04:54:50 PM »
Give this a test drive 8-)
;;  http://www.theswamp.org/index.php?topic=14184.msg171131#msg171131
(defun ss->lst (ss / i ename result)
  (and (eq 'pickset (type ss))
       (setq i -1)
       (while (setq ename (ssname ss (setq i (1+ i))))
         (setq result (cons ename result))
  result
« Reply #14 on: April 01, 2010, 05:19:21 PM »
       (setq i -1)
  result
yep :cool:
LE3
« Reply #15 on: April 01, 2010, 05:44:20 PM »
by looking into the last two post... it took me way back to the x-arch or reni urban place, because of the code style - ish :)
when I was like 4 or 7 years  :lol:  :-P
« Reply #16 on: April 01, 2010, 05:49:32 PM »
Ah yes, the good old daze when Tony would publicly, and gratuitously insult Reini, calling him a fool etc. I also remember coming to your defense several times when you were in his sights. Of course, Tony and I got along famously, almost as well as I got on with Frank Oquendo.  :whistle:
LE3
« Reply #17 on: April 01, 2010, 05:57:48 PM »
any idea of what happen to Frank Oquendo?
and yes the friendly days.... :)
« Reply #18 on: April 01, 2010, 05:59:34 PM »
Don't have a clue, I always assumed he legally changed his name because he appeared to vanish. Maybe Bobby Jones (who occasionally hangs here) knows, they were once business partners of sorts.
« Reply #19 on: April 01, 2010, 06:08:35 PM »
Spider senses are tingling, here comes Bobby now!
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« Reply #20 on: April 01, 2010, 06:10:35 PM »
I hang when possible, I lurk even more, and I try to refrain from trolling as much as possible.
I haven't heard from Frank in a long while.  I miss those good 'ol days too :)
Bobby C. Jones
LE3
« Reply #21 on: April 01, 2010, 06:11:21 PM »
Also, about Robert Bell.... or maybe he is in the ng's still - but I do not frequent there as I use to....
Bobby C. Jones
« Reply #22 on: April 01, 2010, 06:11:49 PM »
That's amazing :)
Bobby C. Jones
Bobby C. Jones
« Reply #23 on: April 01, 2010, 06:13:09 PM »
Bob hangs a lot in the AUGI groups.  I would visit there more often, but I don't like the UI as much as the swamp.
Bobby C. Jones
« Reply #24 on: April 01, 2010, 06:20:42 PM »
evidently :)
once I found the swamp I basically dropped the audesk ngs
That's amazing :)
the powers come and go, if only I could harness them on demand
augi sucks on so many levels :ugly:
« Reply #25 on: April 01, 2010, 07:15:17 PM »
If you really wanted to use recursion, perhaps
(defun ss->lst (ss / f)
  (defun f (i / e)
    (if (<= 0 i)
      (cons (ssname ss i) (f (1- i)))))
  (f (1- (sslength ss))))
But its not really worth it imo, considering the unpredictable sizes of SelSets coupled with the performance deficits of recursive iteration.
alanjt
« Reply #26 on: April 01, 2010, 07:48:57 PM »
  (defun f (i / e)
    (if (<= 0 i)
Nice.
You're probably right. I was more curious than anything.
Dropbox
alanjt
« Reply #27 on: April 01, 2010, 08:05:09 PM »
Counterpart:
;;; Convert list of ename objects to 1 selection set
;;; L - list of enames
;;; Alan J. Thompson, 04.01.10
(defun AT:List->SS (L)
  (if (cdr L)
    (ssadd (car L) (AT:List->SS (cdr L)))
    (ssadd (car L))
  ) ;_ if
) ;_ defun
« Last Edit: April 03, 2010, 09:29:16 AM by alanjt »
Dropbox
