If I define a selection set to a variable, then copy that variable (assign it to another), and the ssdel an ename out of the variable, why does it remove it from the first variable selection set?
eg.
Command: (sslength (setq s1 (ssget)))
Select objects: Specify opposite corner: 8 found
Select objects:
8
Command: (setq s2 s1)
<Selection set: ffea>
Command: (sslength (ssdel (ssname s2 0) s2))
7
Command: (sslength s1)
7
