((lambda ( s ) (substr s 1 (1- (strlen s))))(apply 'strcat (mapcar (function (lambda ( a ) (strcat a ","))) '("a" "b" "c"))))
Thought that might be a concern. Oh well. But in the interest of cat skinning.Code: [Select]((lambda ( s ) (substr s 1 (1- (strlen s))))(apply 'strcat (mapcar (function (lambda ( a ) (strcat a ","))) '("a" "b" "c"))))
(substr (apply 'strcat (mapcar (function (lambda ( a ) (strcat "," a))) '("a" "b" "c"))) 2)
(mapcar (function (lambda(x) (setq str (cond (str (strcat str "," x))(x))))) strlist)
(apply 'strcat (mapcar 'strcat '("a" "b" "c") '("," "," "")))
(defun Str-Make (lst del / str x) (setq str (car lst)) (foreach x (cdr lst) (setq str (strcat str del x)))str)
(defun Str-Make (lst del / str) (setq str (car lst)) (while (setq lst (cdr lst)) (setq str (strcat str del (car lst))))str)
Code: [Select](defun Str-Make (lst del / str x) (setq str (car lst)) (foreach x (cdr lst) (setq str (strcat str del x))) str)Code: [Select](defun Str-Make (lst del / str) (setq str (car lst)) (while (setq lst (cdr lst)) (setq str (strcat str del (car lst)))) str)
Very cool Lee! And to think, I was pretty happy with my recursive one.
(defun Str-Make (lst del / str) (mapcar (function (lambda(s) (setq str (if str (strcat str del s) s)))) lst) str)
(defun Str-Make (lst del / str f) (apply 'strcat (mapcar (function (lambda (s) (setq f (if f (strcat del s) s)))) lst)))
Another Code: [Select](defun StringStrip (str) ;; Lee Mac ~ 01.04.10 (defun StringParser (str del) (if (setq pos (vl-string-search del str)) (cons (substr str 1 pos) (StringParser (substr str (+ pos 1 (strlen del))) del)) (list str))) (StringParser (vl-string-trim "*" str) "*"))Code: [Select](StringStrip "*jsyq_g_list*G1*G2*G3*G4*G5*")==> ("jsyq_g_list" "G1" "G2" "G3" "G4" "G5")
