Author Topic: Purging with ODBX?  (Read 5603 times)
ArgV
Purging with ODBX?
« on: March 31, 2010, 03:39:08 PM »
Just wondering if anyone knows if, or how, to purge a drawing with ODBX? Or if it's even possible?
I realize there are no graphical entities with ODBX, so it would be hard for the application to determine whether an item can be purged or not, but I dunno.
thanks!
Re: Purging with ODBX?
« Reply #1 on: March 31, 2010, 03:45:08 PM »
Yes it is possible but it's an activity that requires more than a quick answer to detail.
ArgV
« Reply #2 on: March 31, 2010, 03:47:03 PM »
I could imagine. Well, I'd love to know how to do it, but if it's super involved then maybe I'll just write a script to do it.
« Reply #3 on: March 31, 2010, 03:50:10 PM »
Can you just use the ' delete ' method?  I thought it wouldn't let you delete items that are referenced.  Not sure though.
TimSpangler
  • CAD Naked!!
« Reply #4 on: March 31, 2010, 03:53:15 PM »
thanks!
Here is some code to purge a block(S).  Modify it to suite your neeeds
;; Check to see if the block is a DW block
(foreach X BlockList
(if (= "DW-" (strcase (substr X 1 3)))
;; Check to see if the block is used and purge it
;; Method Thanks to Jimmy Bergmark
(vl-catch-all-error-p
(vl-catch-all-apply
'vla-delete
(list (vl-catch-all-apply
'vla-item
(list (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) X)
nil ; name cannot be purged or doesn't exist
Here is the code to open and close the drawing.  credit to Credit to jbuzbee.
;;; ------------ OPEN A DBXDOCUMENT
(defun BLOCK_OpenDbx (dbxDrawingName / Application Document dbxDocument dbxOpen)
(setq Application (vlax-get-acad-object))
(setq Document (vla-get-activedocument Application))
(if (/= dbxDrawingName (vla-get-fullname Document))
((= (substr (getvar "ACADVER") 1 5) "15.06")
(setq dbxDocument (vla-GetInterfaceObject Application "ObjectDBX.AxDbDocument"))
(setq dbxOpen (vl-catch-all-apply 'vla-open (list dbxDocument dbxDrawingName)))
(T
(setq dbxDocument (vla-GetInterfaceObject Application (strcat "ObjectDBX.AxDbDocument." (substr (getvar "acadver") 1 2))))
(if (vl-catch-all-error-p dbxOpen)
(setq dbxDocument nil)
(vlax-release-object Application)
(vlax-release-object Document)
dbxDocument
;;; ------------ CLOSE DBXDOCUMENT
(defun BLOCK_CloseDbx (dbxDocument / dbxDocument)
(if (= (type dbxDocument) 'VLA-OBJECT)
(vlax-release-object dbxDocument)
Just start hacking things together.  When you have things some what usable post it.   :mrgreen:
ACA 2015 - Windows 7 Pro
Andrea
« Reply #5 on: March 31, 2010, 04:56:47 PM »
try this...
change the "C:\test\33.dwg" by your drawing name..
(setq AutoCADapp
       (vlax-create-object
(strcat "AutoCAD.Application."
(setq documents (vla-get-documents AutoCADapp))
(setq ii (vla-open documents "C:\\test\\33.dwg" nil))
(vla-sendcommand
  ii
  (strcat "_-purge"
 (chr 13)
 "_A"
 (chr 13)
 "_*"
 (chr 13)
 "_N"
 (chr 13)
(vlax-invoke-method documents "close")
(vlax-invoke-method AutoCADapp "quit")
(mapcar 'vlax-release-object
(mapcar 'eval '(AutoCADapp documents ii))
Keep smile...
« Reply #6 on: March 31, 2010, 05:03:42 PM »
If you are going to open the drawing, then there is no need to use ' sendcommand ', as there is a ' purgeall ' method of a document that is open in editor, even if it's not the current document.
Command: (dump (vla-item (vla-get-documents (vlax-get-acad-object)) "Drawing3.dwg"))
; IAcadDocument: An AutoCAD drawing
; Property values:
<snip>
; Methods supported:
;   Activate ()
;   AuditInfo (1)
;   Close (2)
;   CopyObjects (3)
;   EndUndoMark ()
;   Export (3)
;   GetVariable (1)
;   HandleToObject (1)
;   Import (3)
;   LoadShapeFile (1)
;   New (1)
;   ObjectIdToObject (1)
;   Open (2)
;   PurgeAll ()
;   Regen (1)
;   Save ()
;   SaveAs (3)
;   SendCommand (1)
;   SetVariable (2)
;   StartUndoMark ()
;   Wblock (2)
Krushert
  • FREE BEER Tomorrow!!
« Reply #7 on: March 31, 2010, 05:04:34 PM »
Alright I will play dumb which takes very little effort from me.
What is the significance of checking for the ACAD version?
dgorsman
« Reply #8 on: March 31, 2010, 05:14:51 PM »
One thing I have noticed, that using the Delete method through ODBX will only catch the top-level objects i.e. a block that is part of a block will only delete the parent, not the child.  Not sure if connecting to the file multiple times will solve that.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Krushert
« Reply #9 on: March 31, 2010, 05:17:46 PM »
I have been meaning to ask this question.
I read somewhere that -purge is more through that purgeall.
Is this true?
alanjt
  • Standby for witty remark...
« Reply #10 on: March 31, 2010, 05:28:43 PM »
Know that this will not purge Multileader styles.
; Property values:
<snip>
;   Activate ()
;   AuditInfo (1)
;   Close (2)
;   CopyObjects (3)
;   EndUndoMark ()
;   Export (3)
;   GetVariable (1)
;   Import (3)
;   LoadShapeFile (1)
;   New (1)
;   Open (2)
;   PurgeAll ()
;   Regen (1)
;   Save ()
;   SaveAs (3)
;   SendCommand (1)
;   SetVariable (2)
;   StartUndoMark ()
;   Wblock (2)
Dropbox
« Reply #11 on: March 31, 2010, 05:40:28 PM »
Is this true?
Wouldn't know.  I never ran any tests.  I just know it's there.   :wink:
<snip>
Good to know.  Don't use mleaders yet, so one for the memory bank.
ArgV
« Reply #12 on: March 31, 2010, 05:49:47 PM »
thanks!
(vl-catch-all-apply
'vla-delete
'vla-item
(T
dbxDocument
I'll tinker with that, but as far as I know (which isn't very far, mind you), the objectDBX interface doesn't have a purge method. Though I may be wrong, I didn't see one.
However, if the 'delete' method works like a purge, then I'm golden.
thank you! :)
alanjt
« Reply #13 on: March 31, 2010, 05:54:06 PM »
Is this true?
<snip>
This was my solution...
;;; Purge Multileader Styles (since vla-purgeall ignores them)
;;; Alan J. Thompson, 08.24.09
(defun AT:MleaderStylePurge (/)
  (vl-remove-if
    'null
    (mapcar
      '(lambda (x)
         (and
           (eq 350 (car x))
           (not (eq 330 (car (nth 5 (entget (cdr x))))))
           (not (eq (getvar "cmleaderstyle")
                    (vla-get-name (vlax-ename->vla-object (cdr x)))
                ) ;_ eq
           ) ;_ not
           (entdel (cdr x))
         ) ;_ and
       ) ;_ lambda
      (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE")
    ) ;_ mapcar
  ) ;_ vl-remove-if
) ;_ defun
Dropbox
ArgV
« Reply #14 on: March 31, 2010, 05:58:45 PM »
try this...
(setq AutoCADapp
       (vlax-create-object
(vla-sendcommand
  ii
  (strcat "_-purge"
 (chr 13)
 "_A"
 (chr 13)
 "_*"
 (chr 13)
 "_N"
 (chr 13)
Will this work with ObjectDBX? I noticed this is a standard autocad application, which supports the 'vla-purgeall' command.
