Author Topic: -={ Challenge }=- Subst at n  (Read 7275 times)
« on: March 28, 2010, 06:38:57 PM »
The Challenge: to substitute an item in a list at a specified position.
Example:
(subst_at_n 2 '(0 1 2 3 4 5) 4)
=>  (0 1 2 3 2 5)
I figure there are quite a few ways to do this, so the challenge might be interesting.
I apologise in advance if this has been addressed in the past - I did do a search, but was perhaps not thorough enough.
My entry:
 (defun Subst_at_n (item lst n)
    (if lst
      (cons (if (zerop n) item (car lst))
            (Subst_at_n item (cdr lst) (1- n)))
      (car lst)))
« Last Edit: March 29, 2010, 06:18:30 AM by Lee Mac »
alanjt
  • Standby for witty remark...
Re: -={ Challenge }=- Subst at n
« Reply #1 on: March 28, 2010, 06:49:22 PM »
I wrote this back in June...
;;; Replace nth item in list
;;; #Nth - nth number in list to replace
;;; #New - replacement item
;;; #List - list to process
;;; Alan J. Thompson, 06.16.09
(defun AT:NthReplace (#Nth #New #List / #Count)
  (setq #Count -1)
  (mapcar '(lambda (x)
             (if (eq #Nth (setq #Count (1+ #Count)))
               #New
               x
             ) ;_ if
           ) ;_ lambda
          #List
  ) ;_ mapcar
) ;_ defun
This would be better...
  (if (zerop #Nth)
    (cons #New (cdr #List))
    (progn (setq #Count -1)
           (mapcar (function (lambda (x)
                                 #New
                                 x
                               ) ;_ if
                             ) ;_ lambda
                   ) ;_ function
                   #List
           ) ;_ mapcar
    ) ;_ progn
  ) ;_ if
) ;_ defun
« Last Edit: March 29, 2010, 11:58:35 AM by alanjt »
Dropbox
alanjt
« Reply #2 on: March 28, 2010, 07:05:06 PM »
BTW Lee...
([color=red]Mac-[/color]Subst_at_n item (cdr lst) (1- n)))
Dropbox
« Reply #3 on: March 28, 2010, 07:12:09 PM »
Wowza... I made that change in the post box, something I'm never going to do again... Thanks alan
alanjt
« Reply #4 on: March 28, 2010, 07:15:40 PM »
:) I've done the exact same thing.
Dropbox
« Reply #5 on: March 28, 2010, 07:32:31 PM »
;; variation by CAB
(defun replace_CAB (lst i itm)
  (setq i (1+ i))
  (mapcar '(lambda (x) (if (zerop (setq i (1- i))) itm x)) lst)
« Reply #7 on: March 28, 2010, 07:36:13 PM »
Quick & dirty & just for fun ...
(defun _ReplaceNth ( n item lst / f )
    (defun f ()
        (if (zerop n)
            (progn (defun f () x) item)
            (progn (setq n (1- n)) x)
    (mapcar (function (lambda (x) (f))) lst)
« Reply #8 on: March 28, 2010, 07:39:25 PM »
and for even more fun ...
(defun _ReplaceNth ( n item lst )
    (   (lambda (f) (mapcar (function (lambda (x) (f))) lst))
        (lambda ( )
            (if (zerop n)
 :lol:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #9 on: March 28, 2010, 07:50:39 PM »
#include "stdafx.h"
#include <array>
#include <iostream>
using namespace std;
using namespace std::tr1;
int _tmain(int argc, _TCHAR* argv[])
  array<int,9> ints = {1,2,3,4,5,6,7,8,9};
  ints[2] = 9;
  for_each(ints.begin(), ints.end(), [](int n) { cout << n << " "; });
  cout << endl;
  system("pause");
  return 0;
« Last Edit: March 28, 2010, 07:56:26 PM by Daniel »
LE3
« Reply #10 on: March 28, 2010, 07:55:03 PM »
Be careful don't end like me and be tagged for ever and be part of a real facts...  :lol:  :evil:  :lmao:
Here is something from my very old lisp coding school.-
(defun substAtPosition  (newItem position oldList / cont lth lst)
  (setq cont 0
lth  (length oldList))
  (while (/= cont position)
    (setq lst (append lst (list (nth cont oldList)))
 cont (1+ cont)))
  (setq lst (append lst (list newItem))
cont (1+ cont))
  (while (< cont lth)
 cont (1+ cont)))
  lst)
(substAtPosition 2 4 '(0 1 2 3 4 5))
(0 1 2 3 2 5)
« Reply #11 on: March 28, 2010, 10:36:52 PM »
sick puppy  :-P
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: March 28, 2010, 11:41:46 PM »
I thought you might like the lambda expression, I can format it like lisp  :laugh:
for_each(
 ints.begin(),
    ints.end(),
« Reply #13 on: March 29, 2010, 06:20:27 AM »
Nice one Michael - I love that 'double-defun' trick  :lol:
« Reply #14 on: March 29, 2010, 06:22:28 AM »
http://www.theswamp.org/index.php?topic=14170.0
I knew there would be another one, there was no way this operation was untouched  :evil:
