Author Topic: linetype (Load) Question  (Read 3430 times)
V-Man
« on: November 30, 2004, 03:49:40 PM »
Is there a better way to import linetypes into a drawing?
(defun c:Ltest ()
(setvar "cmdecho" 0)
(setq Ldashed "DASHED")
  (if  (not (tblsearch "LTYPE" Ldashed))
  (CREATE_LINETYPES Ldashed)
(defun CREATE_LINETYPES (LineType /)
        (setq LtypePath (findfile "acad.lin"))
  (command "linetype" "load" LineType  LtypePath "" "")
This code works but it also says unknown command after it runs. Any ideas? Or better ways of writing?
David Bethel
« Reply #1 on: November 30, 2004, 04:57:29 PM »
Creating LineTypes has never been pretty.
(defun SetLType (n d f / lf rf nl)
;;;LineType_Name Descriptor File_name
 (cond ((not (findfile (strcat f ".LIN")))
        (setq lf (open (strcat f ".LIN") "w"))
        (write-line ";; Specialty LineTypes" lf)
        (write-line "" lf)
        (close lf)
        (command "_.LINETYPE" "_Create" n f
                 "----- ----- ----- ----- ----- -----" d ""
                 "_.LINETYPE" "_Load" n f ""))
      ((not (tblsearch "LTYPE" n))
       (setq rf (open (strcat f ".LIN") "r"))
       (while (setq nl (read-line rf))
              (if (wcmatch nl (strcat "`*" n ",*"))
                  (setq ex T)))
       (close rf)
       (if (not ex)
                    "----- ----- ----- ----- ----- -----" d ""))
       (command "_.LINETYPE" "_Load" n f "")))
n)
Usage:
  (SetLType "Dash" "1.25,-.25,.25,-.25,.25,-.25" "TEMP1")
-David
R12 Dos - A2K
V-Man
« Reply #2 on: November 30, 2004, 05:05:28 PM »
Sorry if I was not clear. I need to know if there are easier (better) ways to LOAD linetypes not create them......??
David Bethel
« Reply #3 on: November 30, 2004, 05:17:02 PM »
First, you need to verify that the linetype file exists in a search path directory.
Second, verify that a linetype definition already exists for the named LType
Third, that the linetype is not already loaded
Otherwise the error message start popping up.
What I posted was a generic loader that insures that the linetype given is indeed loaded, basically no matter what the error is.
For a standard ACAD LType (SetLType "HIDDEN" "" "ACAD")
-David
R12 Dos - A2K
« Reply #4 on: November 30, 2004, 06:16:19 PM »
Not sure where I picked this up at:
;;; FIND-LINE-TYPES                                                   ;
;;; This searches a linetype collection object and determines if      ;
;;; the linetype is present in the collection.                        ;
;;; Note: l-obj is a local variable within the scope of the vlax-for  ;
;;;       function because it is used within a "for" expression       ;
;;; Arguments: line-type = A string which denotes the linetype        ;
;;;                        to search for in the line-type-collection  ;
;;;                        argument.                                  ;
;;;            line-type-collection = A vla collection object which   ;
;;;                                   contains the current linetypes  ;
;;;                                   loaded in ACAD.                 ;
;;; Returned Value: If the linetype is found a vla linetype object    ;
;;;                 is returned such as:                              ;
;;;                 #<VLA-OBJECT IAcadLineType 03fe0b00>              ;
;;;                 (If the linetype search fails this function       ;
;;;                  returns n(defun TxtStr (x)
;;; Usage: (load-line-types "CENTER" "acad.lin")                      ;
(defun find-line-type (line-type line-type-collection / res)
  (setq line-type (strcase line-type))
  (vlax-for l-obj line-type-collection
    (if (= (strcase (vla-get-name l-obj)) line-type)
      (setq res l-obj)
  res
;;; LOAD-LINE-TYPES                                                   ;
;;; This function loads a linetype in to the drawing                  ;
;;; Required Functions: find-line-type                                ;
;;; Arguments: line-type = A string which denotes the LT to load      ;
;;;            file-name = A string which denotes the LT file to      ;
;;;                        which to load the requested linetype       ;
;;; Returned Value:  A vla linetype object objects such as:           ;
(defun load-line-types (line-type file-name / tmp res)
  (if (and (setq tmp (vlax-get-acad-object))
           (setq tmp (vla-get-activedocument tmp))
           (setq tmp (vla-get-linetypes tmp));; linetypes is the last
                                             ;; set and the current
                                             ;; linetype collection
    (if (setq res (find-line-type line-type tmp))
      res
       ;; load the linetype
        (vla-load tmp line-type file-name)
       ;; since the vla-load function returns nil
       ;; we force the following function to test if
       ;; the load was successful. If success the
       ;; return the vla linetype object
        (if (vla-item tmp line-type)
          ;; Nothing was loaded so we return nil
          nil
        )   ;; _test to see if the line was loaded
      )     ;; evaluate when the linetype is not loaded in acad
    )       ;; end if for check if linetype is loaded
    nil
  )         ;; end if for various calls to ACAD
CADaver
« Reply #5 on: November 30, 2004, 06:24:24 PM »
I just load 'em all.
(defun c:ltla ()
(setq ans "")
  (command ".linetype" "l" "*" "e:/programs/ac2002/menus/csa/acad"
    (while (/= (getvar "cmdnames") "")
      (command ans)
David Bethel
« Reply #6 on: November 30, 2004, 07:00:03 PM »
CADaver,
I agree with you on that approach.
(defun c:lltype (/ file rf nl i lt)
 (and (setq file (getfiled "Line File to Edit" "/acad/" "lin" 2))
      (setq rf (open file "r"))
      (princ "\nLoading LineTypes")
             (if (= "*" (substr nl 1 1))
                   (setq i 1)
                   (while (/= "," (substr nl i 1))
                          (setq i (1+ i)))
                   (setq lt (substr nl 2 (- i 2)))
                   (and (not (tblsearch "LTYPE" lt))
                        (princ (strcat "\rLoading " (strcase lt)))
                        (command "_.LINETYPE" "_Load" lt file "")))))
      (close rf))
 (prin1))
-David
R12 Dos - A2K
V-Man
« Reply #7 on: December 01, 2004, 07:47:03 AM »
Off the beaten path, but do you have anything that does the same thing for text STYLES?
David Bethel
« Reply #8 on: December 01, 2004, 08:05:25 AM »
Styles are even more of a pain the ltypes to me, Unless you just want the table setup.
(defun SetStyle (s)
 (if (or (/= 'STR (type s))
         (and (not (tblsearch "STYLE" s))
              (and (not (findfile (strcat s ".SHX")))
                   (not (findfile (strcat s ".PFB"))))))
      (err (strcat "Cannot Access Text Style " s)))
 (command "_.STYLE" s s)
 (while (> (getvar "CMDACTIVE") 0)
           (command "")))
As you can see from the .PFB file type, this is a very old routine.  -David
R12 Dos - A2K
