Author Topic: Strip block of Dynamic Properties  (Read 29582 times)
Shade
« on: March 23, 2010, 01:07:55 PM »
Does any one have a lisp that will strip the dynamic properties from dynamic blocks?
I have an extensive DB library which I use quite heavily throughout my drawings, some payed for, others spent serious time on developing.
I starting freelance drafting about a year ago and would like to protect my investment in the DB's, both in money as well as time and effort.
My DB collection helps me produce drawings quicker and more accurately then the clients can in house.  Which is why my clients come to me with the work.
I have released the dwg files with the DB's, in them to the clients and have notice they are starting to use them in their offices.
One client has drop my services altogether because he is able to work cheaper in house with my DB collection then before.
I would like to strip any DB from my drawings to prevent other's from following suit.
The only way I figure to protect my db now is to explode all blocks before transferring to the clients.
If anyone has a better way of protecting my investment, please feel free to express it.
Any help would be greatly appreciated.....
Shade  :mrgreen:
Re: Strip block of Dynamic Properties
« Reply #1 on: March 23, 2010, 01:10:05 PM »
What version of AutoCAD? What happens if you do a "Save As" to the lowest version available, does that "lobotomize" the dynamic blocks?
edit: DOH, just saw your sig. Last question stands.
Engineering Technologist CAD Automation Practitioner
cadanalyst@gmail.com http://cadanalyst.slack.com http://linkedin.com/in/cadanalyst
« Reply #2 on: March 23, 2010, 01:35:55 PM »
Okay, that doesn't work. I have 2008. Saved to r14 and re-opened -- the dynamic data round tripped ok.
Some lisp should be able to lobotomize it no prob tho.
alanjt
  • Standby for witty remark...
« Reply #3 on: March 23, 2010, 01:39:26 PM »
Just an example:
(vla-ConvertToStaticBlock (vlax-ename->vla-object (car (entsel))) "NewName")
Dropbox
« Reply #4 on: March 23, 2010, 01:42:29 PM »
yep
alanjt
« Reply #5 on: March 23, 2010, 01:46:29 PM »
Granted, if you select multiples of the same Dynamic block, it will error. However, you just convert the first one, then rename the remaining accordingly.
(vla-put-name x "NewName")
Dropbox
« Reply #6 on: March 23, 2010, 02:13:21 PM »
Be careful, that strategy will introduce errors unless all instances of a given block share the same state.
« Reply #7 on: March 23, 2010, 02:31:35 PM »
Just an example:
That's a new one for me thanks Alan  :-)
alanjt
« Reply #8 on: March 23, 2010, 02:36:05 PM »
Oh yeah, I wasn't thinking about that.
Just an example:
:)  I remembered seeing it a while back when I wrote the routine that allows one to change the visibility states for multiple Dynamic blocks at once.
Dropbox
« Reply #9 on: March 26, 2010, 01:43:38 PM »
Friday quick & dirty freebie ... not the most efficient but free ...
(defun c:UnDynamic
        _get_item
        _right
        _make_key
        _dynamic->static_block
        _get_locked
        _get_dynamic_inserts
        _main
    (defun _get_item ( collection key / item )
        (vl-catch-all-apply
           '(lambda ( ) (setq item (vla-item collection key)))
        item
    (defun _right ( str n / len )
        (if (< n (setq len (strlen str)))
            (substr str (1+ (- len n)))
            str
    (defun _make_key ( collection prefix len / key )
        (   (lambda ( i pad )
                (while
                    (_get_item collection
                        (setq key
                            (strcat prefix
                                (_right
                                    (strcat pad (itoa (setq i (1+ i))))
                                    len
                key
            0
            (   (lambda ( pad )
                    (while (< (strlen pad) len)
                        (setq pad (strcat "0" pad))
                    pad
    (defun _dynamic->static_block ( blocks insert len )
            insert
            (_make_key blocks "STATIC_" len)
    (defun _get_locked ( layers / locked )
        (vlax-for layer layers
            (if (eq :vlax-true (vla-get-lock layer))
                (setq locked (cons layer locked))
        locked
    (defun _get_dynamic_inserts ( blocks / inserts )
        (vlax-for block blocks
            (vlax-for object block
                (if (eq "AcDbBlockReference" (vla-get-objectname object))
                    (if (eq :vlax-true (vla-get-isdynamicblock object))
                        (setq inserts (cons object inserts))
        inserts
    (defun _main ( document / blocks inserts locked len )
            (setq inserts
                (_get_dynamic_inserts
                    (setq blocks (vla-get-blocks document))
                (foreach layer (setq locked (_get_locked (vla-get-layers document)))
                    (vla-put-lock layer :vlax-false)
                (setq len (strlen (itoa (length inserts))))
                (foreach insert inserts
                    (_dynamic->static_block blocks insert len)
                (foreach layer locked
                    (vla-put-lock layer :vlax-true)
    (_main (vla-get-activedocument (vlax-get-acad-object)))
alanjt
« Reply #10 on: March 26, 2010, 02:01:55 PM »
Alan is right, you really are an artist. Nice work.
Dropbox
« Reply #11 on: March 26, 2010, 02:16:11 PM »
x2   :-)
« Reply #12 on: March 26, 2010, 02:38:59 PM »
Tall praise given the source(s). Someday I will be worthy. Thanks guys.
trogg
« Reply #13 on: November 14, 2010, 10:22:32 PM »
In my CAD customization class, we were warned that after we saved our drawings with dynamic blocks, if we save them as a .dxf we would lose the dynamic block functions and any hyper-links.
just a thought from a newbie.
Although - I really like the code though too
cmwade77
« Reply #14 on: November 15, 2010, 01:43:23 PM »
The .dxf method would work, but may introduce more errors too.....the code looks good too though.
