Author Topic: ResbufList class  (Read 14326 times)
pkohut
Re: ResbufList class
« Reply #30 on: March 25, 2011, 12:48:09 AM »
Good code,but I don't know how to use.
See this post for ResbufList in use.
http://www.theswamp.org/index.php?topic=28286.0
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #31 on: March 25, 2011, 06:57:54 PM »
Thanks Paul!
On your second entry, will that even compile? I always thought those args in the for loop had to be of the same type.  :mrgreen:
Dan
pkohut
« Reply #32 on: March 25, 2011, 07:06:40 PM »
You're right. The declaration of nItems should be outside, however the assignment will still work inside.
size_t nItems = 0;
for(resbuf *pRbTemp = mpHead ; pRbTemp != NULL ; pRbTemp = pRbTemp->rbnext, ++nItems)
    if(idx == nItems)
        return pRbTemp;
... do lots of work
for(nItems =0, resbuf *pRbTemp = mpHead ; pRbTemp != NULL ; pRbTemp = pRbTemp->rbnext, ++nItems)
    if(idx == nItems)
        return pRbTemp;
