Author Topic: Hatch Area Question...  (Read 6794 times)
alanjt
  • Standby for witty remark...
« on: March 17, 2010, 09:52:03 AM »
I encountered a problem over at CADTutor and I was curious if any of the experts here might be able to shine some light on the situation.
Has anyone ever tried to get the area from a hatch object and been unsuccessful? I posted a very simple piece of code to tally the area of selected hatch objects. Problem is, the user cannot see the area of a selected hatch. If he LISTs the object, an area is not display and if he runs a (vlax-dump-object, the spot where ; Area - ### would be is missing. I get the area value (even from a posted drawing) and Lee was able to get the value.
Any thoughts?
Dropbox
Re: Hatch Area Question...
« Reply #1 on: March 17, 2010, 10:00:12 AM »
The area property will be null if an unbound entity / selection is hatched, e.g. an un-closed polyline.
alanjt
« Reply #2 on: March 17, 2010, 10:30:34 AM »
The drawing just has closed LWPolylines. Most likely drawn with Rectangle.
Dropbox
« Reply #3 on: March 17, 2010, 10:34:10 AM »
All 3 hatches in that drawing sport valid area property values, so I don't understand why it was posted.
alanjt
« Reply #4 on: March 17, 2010, 10:35:34 AM »
I know. That's what makes this so confusing.
Link: http://www.cadtutor.net/forum/showthread.php?p=310953&posted=1#post310953
Dropbox
« Reply #5 on: March 17, 2010, 10:44:32 AM »
I question whether the drawing posted here is the same in question over there.
alanjt
« Reply #6 on: March 17, 2010, 10:55:28 AM »
I asked that same thing before and asked again, just to make sure.
Response: Yes and I made an additional drawing with one hatch with a rectangle as well. The same problem exists in both drawings. I also tested this on two versions of acad as previously mentioned (2004 & 2009).
Dropbox
« Reply #7 on: March 17, 2010, 11:06:05 AM »
Wut. All three hatches show the area property via the list command, all three hatches show a valid area property via lisp. ???
PS: AutoCAD 2008, vanilla.
alanjt
« Reply #8 on: March 17, 2010, 11:11:04 AM »
I know. I'm completely lost/confused. He tested it in vanilla 04 & 09, I tested it in C3D 09 and Lee tested it in vanilla 2010.
Dropbox
« Reply #9 on: March 17, 2010, 11:13:27 AM »
I'm lost too... the only way I can actually get the Area to be null is to do as you say Michael, and hatch an open poly - but even in this case, the area property is still shown in the dump, just as an invalid value. In the CADTutor thread, the dump reveals no Area property whatsoever. I'm testing in ACAD 2010 Student and the posted DWG seems fine to me.
« Last Edit: March 17, 2010, 11:19:02 AM by Lee Mac »
« Reply #10 on: March 17, 2010, 11:16:37 AM »
Let me be clear: based on what was posted I see no problem.
It's either a student version anomaly (doubtful) or a PEBKAC error based on what I've seen thus far. Shrug.
alanjt
« Reply #11 on: March 17, 2010, 11:20:59 AM »
I hate not being able to find an answer, but without sitting at the computer, how can I? This is just so bizarre.
Dropbox
hmspe
« Reply #12 on: March 17, 2010, 01:11:59 PM »
I seem to remember having similar problems in the past.  One computer in the office would not report hatch areas but the other two would.  All computers had the same version of Autocad set up in the same way, and all were pulling the same file from a server.  As I recall two of the computers were identical except for video cards, and it was one of those two that would not report hatch area.  I checked system variables, settings, etc. and never found a solution.  I think we were running 2004 at the time.
"Science is the belief in the ignorance of experts." - Richard Feynman
« Reply #13 on: March 17, 2010, 02:00:26 PM »
My understanding is that if the hatch is associative then there is an area else not.
« Reply #14 on: March 17, 2010, 02:07:17 PM »
Sorry CAB, not true.
====================================Object====================================
<IAcadHatch 2124801128> (8/8 of <IAcadModelSpace2 2124774648>)
==================================Properties==================================
Application              <IAcadApplication>
[color=red]Area                     30.9975
AssociativeHatch         :vlax-false[/color]
Color                    256
Database                 <IAcadDatabase>
Document                 <IAcadDocument>
Elevation                0.0
EntityName               AcDbHatch
