Author Topic: Using a temporary computer & ACAD system?  (Read 11484 times)
Re: Using a temporary computer & ACAD system?
« Reply #15 on: March 17, 2010, 11:56:12 AM »
Not sure if this helps you Alan?
;; Out = Filename of Output File
(defun GetBitMaps (out / lst tag) ;; Lee Mac
  (cond (  (setq f (open out "w"))
           (vlax-for Men (vla-get-MenuGroups (vlax-get-acad-object))
             (vlax-for Tool (vla-get-Toolbars Men)
               (vlax-for Butt Tool
                 (if (not (vl-catch-all-error-p
                            (vl-catch-all-apply (function vla-GetBitMaps)
                              (list Butt 'Small 'Large))))
                   (write-line (strcat (vla-get-Name Butt) "\t" Small "\t" Large) f)))))
           (not (close f)))))
(defun c:test (/ fl)
  (if (and (setq fl (getfiled "Output" "" "txt" 1))
           (GetBitmaps fl))
    (startapp "notepad" fl))
  (princ))
« Reply #16 on: March 17, 2010, 12:26:54 PM »
Thanks Lee, but not interested in ACAD's standard menu's, just my additions.
I may find a use for the routine though.
« Reply #17 on: March 17, 2010, 12:32:44 PM »
Of course the routine cycles through everything - you could easily add conditionals along the way to get at what you want  :-)
Just throwing it out there  :-)
« Reply #18 on: March 17, 2010, 12:47:06 PM »
Lee I appreciate every bit of help. :-)
So the process is like this:
Add thumb drive to "Support File Search Path"  (assuming all files are in the root folder)
At the command line enter MenuLoad CAB1
CAB1 being the CAB1.mns file
The menu is loaded & then the MNL file is executed
In the CAB1.MNL file I would have :
(if (/= (type (load "AlansAutoLoad" "AlansAutoLoad not found")) 'STR)
  (AlansAutoLoad) ; loads everything else needed if found
At this time i have no pull down menus to contend with only buttons & fly-outs
« Reply #19 on: March 17, 2010, 12:52:26 PM »
Alan,
I've probably posted this before....but if you go the route of using resource hacker and putting your bmps into a dll this will save you some time. All you need is an empty dll, reshacker.exe, and some images in the same directory :)
(defun c:reshackerscript (/ bmps dir dll dllnew file fname)
  (if (and (setq
    fname (getfiled "Select a DLL to process (BMPS must be in same directory)"
    "dll"
    8
  (setq dir (vl-filename-directory fname))
  (setq dll (strcat (vl-filename-base fname) ".dll"))
  (setq dllnew (strcat "NEW-" dll))
  (setq bmps (vl-directory-files dir "*.bmp"))
  (setq file (open (strcat dir "\\reshackerscript.txt") "w"))
      (write-line
(strcat "[FILENAMES]\nEXE=" dll
"\nSAVEAS=" dllnew
"\nLOG=\n\n[COMMANDS]\n"
"-delete   BITMAP,,0"
file
      (while (setq fname (car bmps))
(write-line
 (strcat "-addoverwrite " fname ", BITMAP," (vl-filename-base fname) ",0")
 file
(setq bmps (cdr bmps))
      (close file)
      (alert
(strcat
 "Reshacker commandline script syntax:
 \n\n(dir)reshacker.exe -script reshackerscript.txt\n\n
 It's easiest if reshacker.exe, BMP files and reshackerscript.txt
 all reside in the same directory."
      (command "._shell" "CMD")
Krushert
  • FREE BEER Tomorrow!!
« Reply #20 on: March 17, 2010, 12:54:54 PM »
I think I am late to the party but May I suggest in lieu of a thumb drive that you have plug in and unplug every time you switch computers, I would suggest a external hard dive with a USB splitter cable.  That way all your stuff is in one spot and besides CAB, I have a feeling that you would have some automated routine doing half your drawing for you on this temporary computer anyway.   ^-^ :roll:
« Reply #21 on: March 17, 2010, 12:58:23 PM »
Well, bigger is better & faster maybe. 8-) Thanks
« Reply #22 on: March 17, 2010, 12:59:33 PM »
Ron, would the dll be windows specific?
I'm on Windows 2000.
« Reply #23 on: March 17, 2010, 01:02:59 PM »
I don't think so ... but I'm not certain. Mark had a tutorial and an empty dll file he posted many moons ago that I could not find.
deegeecees
« Reply #24 on: March 17, 2010, 01:12:37 PM »
I use a 60GB Seagate, and a combination of Lisp/VBA for adding the drive to the support paths. The speed issue is so negligible it's hardly noticeable.
nivuahc
« Reply #25 on: March 17, 2010, 01:20:20 PM »
Also late to the party but this is what I do;
I have all of my CAD stuff on a thumb drive (as well as TrueCrypt, the PortableApps suite with FireFox, and everything else I might want/need).
I install TrueCrypt on a machine* that I'll be working on and create an encrypted volume on the hard drive. I add the volume to my favorites, setup hotkeys to mount that volume with the provided password, and copy what I need to that mounted volume.
So when I login in the morning I do a CTRL+ALT+Up Arrow, type in my password, then launch AutoCAD. Every now and then I sync my thumb drive with what I've got stored in that hidden volume (which, btw, I give a name like .NTFilesys and place in the C:\Windows folder so prying eyes aren't tempted to delete it). All of my 'personal' stuff gets put in that volume... CAD related stuff as well as things such as PDF's that I want to reference from time to time (like the one that came with my purchase of that book on Python).
The benefits of this are that my drive letter will always be the same (G: for me, at this job) and if I get a call this evening telling me that my services are no longer needed there's nothing that I need to do. Without knowing that the volume is even there, no one is liable to try and mount it. And without knowing the password to the hidden volume within, no one is going to be able to use/rape my stuff.
* In the event that I'm unable to install TrueCrypt on a machine I just copy the executable to a folder somewhere on the hard drive and run it when I need it. Having it start up as a service in Windows just saves me a couple of steps.
cmwade77
« Reply #26 on: March 17, 2010, 01:41:32 PM »
Thanks Michael.
The only scenario I wish to avoid is leaving all my lisp files if I get a call that we no longer need your services.
So an unprotected thumb drive should do the trick.
Provided they allow you to use it.  Our IT department has USBs disabled (except for mice and keyboards).   :|
What you mean you aren't the IT Manager too?
I am the CAD/BIM/IT Manager here.
Seriously, I only disable USB ports on public machines (I also use Windows Steady State on such machines to restore them whenever they are rebooted).
« Reply #27 on: March 17, 2010, 04:25:15 PM »
Kerry,
How do you run the MNL file?
I wish this was extra. The housing market is so bad I have no work. I have not been an employee since 1977. :-(
The MNL file loads automatically with an MNU or MNS file of the same name.
plus:
The folder that the .MNU, .MNL, icons etc are in does NOT need to be on the AutoCAD path. Once the MNU is loaded all related files are 'known' relative to the menu file location.
Chris
« Reply #28 on: March 18, 2010, 08:21:27 AM »
I have had to work at one of our other offices in the past, and in order to overcome the temporary-ness, I had a routine that would renable the flash drive support, then I would just plug in my flash drive and run customizations from there.
Here at my office, all the customization in one folder. All I have to do is add the main path to the top of the list, and that causes the acaddoc.lsp to load, which loads everything, I have programs that load custom menus, other programs, tool palettes, etc.  And on top of all that, every one of the custom routines I use are encrypted and have a security check to see if a particular file exists in a particular location, if not, none of the programs run. (the only disadvantage to this is if your flash drive keeps changing drive letters from computer to computer.
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
« Reply #29 on: March 23, 2010, 11:19:43 AM »
Thanks for all the help.
As as result I moved my "AlansAutoLoad.lsp" to the CAB1.mnl file for loading.
It contains all the LOAD & AUTOLOAD commands as well as some short lisp helpers.
Then I created these lisps to copy the lisp & bmp files.
This does not address the shx & lin files which I moved manually.
I can now use the flash drive for the lisp & menu.
The problem with ACAD2000 is that the icons are not found even when the path is added to ACAD.
I don't expect to be using ACAD2000 though and the job has not materialized.
Sent out mode resumes today.
Dedicated routines, FYI.
;;  by CAB 3.22.2010
;;  reads a MNS file and creates a text file listing all bmp file names found
;;  and copies the bmp file to the flash drive
(defun c:MyIcons (/ file path ICON_lst fn ln data ptr LineStr MNSfile OutFile
                    drive msg)
  (setq MNSfile "CAB1.mns"
         OutFile "Icons.txt"
         drive   "E:\\ACAD\\"  ;  folder on the Flash Drive must exist
  ;;  return a list of text string for each line in the file
  (defun ReadFile (fname / fn ln AllLines)
    (if  (setq fn (findfile fname)) ; only if the file is found
      (progn                                 ; fn contains the full path
         (setq fn (open fn "r"))             ; open file for reading
         (while (setq ln (read-line fn))     ; read all the lines in the file
           (setq AllLines (cons ln AllLines))
         (close fn)                          ; close the open file handle
    AllLines
  ;;  parser by CAB single character delim, match ","
  (defun sparser (str delim / ptr lst)
    (while (setq ptr (vl-string-search delim str))
      (setq lst (cons (substr str 1 ptr) lst))
      (setq str (substr str (+ ptr 2)))
    (reverse (cons str lst))
  ;;  CAB 3.19.2010
  ;;  returns a list with nil & message upon failure
  ;;  returns '(t "File Copy Completed.") when successful
  (defun xcopy (source dest)
      ((not (setq source (findfile source))) '(nil "Source File not found."))
      ((not (vl-file-directory-p (vl-filename-directory dest)))
       '(nil "Destination folder not found."))
      ((and (findfile dest) (not (vl-file-delete dest)))
       '(nil "Destination file exist and can not be deleted."))
      ((not (vl-file-copy source dest)) "File Write Failed.")
      (t '(t "File Copy Completed."))
  ;;  Read the MNS file looking for the first bmp in each line
  ;;  add the bmp to the list' find the second bmp & add it too
  ;;  Write results to Icon.txt file & copies to the flash drive
  (if (setq data (ReadFile MNSfile))
      (princ "\nWorking...\n")
      (setq path (vl-filename-directory (findfile MNSfile)))
      (while (setq LineStr (car data))
         (setq data (cdr data))
         (foreach part (sparser LineStr ",")
           (if (vl-string-search ".bmp" part)
               (setq part (vl-string-trim "\" \t\n" part)
                      part (substr part 1 (+ 4 (vl-string-search ".bmp" part)))
               (setq ICON_lst (cons part ICON_lst))
      )                                      ; while
      (if (setq fn (open (strcat path "\\" OutFile) "w")) ; open file for writing
           (write-line (strcat "BMP files used in " MNSfile) fn)
           (write-line (strcat "Date: " (rtos (getvar 'cdate) 2 4)) fn)
           (foreach ln ICON_lst              ; write all the sorted data
             (write-line (strcat ln "  ==  " (findfile ln)) fn)
                  (if (car
                       (setq msg (xcopy ln
                                         (strcat drive
                                                  (vl-filename-base ln)
                                                  (vl-filename-extension ln)))))
                    (write-line (strcat "     ***  " (cadr msg) "to " drive) fn)
                    (write-line (strcat "     -=< ERROR >=-  " (cadr msg)) fn)
      (and fn (close fn))           ; close the open file handle
      (princ (strcat "\nData File List --> " (strcat path "\\" OutFile)))
;;  by CAB 3.22.2010
;;  reads a LISP file and creates a text file listing all loaded routines
;;  associated with LOAD or AUTOLOAD and
;;  copies the files to the flash drive
(defun c:MyLisp (/ path LISP_lst fn ln data ptr1 ptr2 lsp LineStr LispFile OutFile found
                   itm drive msg)
  (setq LispFile "AlansAutoLoad.lsp" ; read this file for list of LISP files
         OutFile  "MyLisp.txt"
    AllLines
  (defun unique (lst / result)
    (while (setq itm (car lst))
      (setq lst    (vl-remove itm lst)
            result (cons itm result)
  ;;  CAB 3.19.2010
  ;;  Read the "AlansAutoLoad.lsp" file looking for any LOAD or AUTOLOAD
  ;;  add the lisp name to the list
  ;;  Copy the LISP file to the flash drive
  ;;  Write results to "MyLisp.txt" file
  (if (setq data (ReadFile LispFile))
      (setq path (vl-filename-directory (findfile LispFile)))
      (while (setq LineStr (car data)) ; process each line
         (setq Linestr (strcase LineStr)
               data    (cdr data))
           ((and (setq ptr1 (vl-string-search "AUTOLOAD " Linestr))
                  (or (not (or (setq ptr2 (vl-string-search ";" Linestr))
                                (setq ptr2 (vl-string-search "\"" Linestr))
                      (< ptr1 ptr2)))
            (setq ptr1 (vl-string-search "\"" Linestr ptr1))
            (setq ptr2 (vl-string-search "\"" Linestr (1+ ptr1)))
            (setq lsp (substr Linestr (+ ptr1 2) (- ptr2 ptr1 1)))
            (if (vl-string-search ".LSP" lsp)
              (setq lsp (substr lsp 1 (- (strlen lsp) 4)))
            (setq LISP_lst (cons lsp LISP_lst))
           ((and (setq ptr1 (vl-string-search "LOAD " Linestr))
                      (< ptr1 ptr2)))
         ) ; cond
      )  ; while
           (write-line (strcat "Loaded files used in " LispFile) fn)
           (setq LISP_lst (vl-sort (unique LISP_lst) '<))
           (foreach ln LISP_lst              ; write all the sorted data
             (if (cond ;  .vlx .fas .lsp
                    ((setq found (findfile (strcat ln ".VLX")))
                      (setq ln (strcat ln ".VLX")))
                    ((setq found (findfile (strcat ln ".FAS")))
                      (setq ln (strcat ln ".FAS")))
                    ((setq found (findfile (strcat ln ".LSP")))
                      (setq ln (strcat ln ".LSP")))
                 (write-line (strcat ln "  ==  " found) fn)
                  (if (car
                       (setq msg (xcopy found
                                         (strcat drive
                                                  (vl-filename-base found)
                                                  (vl-filename-extension found)))))
               (write-line (strcat ln "  ==  Not found") fn)
      (princ (strcat "\nLoaded File List --> " (strcat path "\\" OutFile)))
