Author Topic: How to make AND work?  (Read 1353 times)
jmcshane
« on: March 16, 2010, 07:15:27 AM »
In a (vlax-for ) expression I am trying to grab an MText object which has a specific word in it.
Can anyone enlighten me as to why this doesn't work?
     (if (and (= (vla-get-ObjectName obj) "AcDbMText")
                 (wcmatch (strcase (vla-get-TextString obj)) "COPYRIGHT"))
          (progn......)
Thanks in Advance
John
John.
Civil 3D 2021. Windows 10
Joe Burke
Re: How to make AND work?
« Reply #1 on: March 16, 2010, 08:07:47 AM »
John,
Consider...
Command: (setq str "THIS COPYRIGHT NOTICE")
Command: (wcmatch str "*COPYRIGHT*")
T
Command: (wcmatch str "COPYRIGHT")
nil
« Reply #2 on: March 16, 2010, 08:17:36 AM »
It is also case sensitive.
« Reply #3 on: March 16, 2010, 08:24:10 AM »
An alternate method to consider.
(vl-string-search pattern string [start-pos])
Searches for the specified pattern in a string
(setq str "THIS copyright notice")
(vl-string-search "COPYRIGHT" (strcase str))
or
(wcmatch (strcase str) "*COPYRIGHT*")
jmcshane
« Reply #4 on: March 16, 2010, 08:28:06 AM »
Consider...
T
nil
Ouch Joe.  That was so obvious, it hurts. :oops:
Thanks CAB, I was using the STRCASE against it.
John.
Joe Burke
« Reply #5 on: March 16, 2010, 08:43:49 AM »
John,
It's all good  :-)
