Author Topic: ask for some help  (Read 2457 times)
lc_shi
ask for some help
« on: November 29, 2004, 02:44:05 AM »
Hi Sirs,
     Belowed is a short lisp for adding a box for a text (in a tutorial site),but it can't works, i can't fault these lisp. Pls give me a hand. Thanks
(DEFUN C:TEXT_F ( ) (SETQ OBJ (ENTSEL "\nSelect Text : "))
 (IF (= OBJ NIL) (PRINC "\nNone Object Select") (PROGN
        (SETQ ENT (ENTGET (CAR OBJ)))
        (IF (/= CDR (ASSOC 0 ENT)) "TEXT")
                (PRINC "\nObject Type Error") (PROGN
                (SETQ TEMP (CADR (TEXTBOX (LIST (ASSOC 1 ENT))))
                        TEMP_W (CAR TEMP) TEMP_H (CADR TEMP)
                        PT_BASE (CDR (ASSOC 10 ENT)))
                (COMMAND "PLINE" PT_BASE
                (SETQ PT_TEMP (POLAR PT_BASE 0 TEMP_W))
                (SETQ PT_TEMP (POLAR PT_TEMP (/ PI 2) TEMP_H))
                (SETQ PT_TEMP (POLAR PT_TEMP PI TEMP_W)) "C")
 (PRINC))
ask for some help
« Reply #1 on: November 29, 2004, 03:51:06 AM »
The code is missing a left parenthesis in this line:
change it to:
 (IF (/= (CDR (ASSOC 0 ENT)) "TEXT")
Although it allows this code to run, the "textbox" function will probably not give you the results you want, without adjusting for rotation angle, obliqueing angle, etc.
ask for some help
« Reply #2 on: November 29, 2004, 04:00:35 AM »
Beat me by a heartbeat Jeff ..
.. also need to allow for the textsize
hyposmurf
ask for some help
« Reply #3 on: November 29, 2004, 03:38:52 PM »
Already been given the answer I know but if you run your original lisp the error you get, suggests you need to look at your parenthesis
; error: extra right paren on input
lc_shi
ask for some help
« Reply #4 on: November 29, 2004, 10:07:51 PM »
i'll try to fix it. it can't works. I doubt it's selected for example.
